help with 2 step install....????
Old Aug 14, 2002 | 05:30 PM
BOOSST's Avatar
Default help with 2 step install....????
ok, i got the 2 step from harlan and he has been very helpful with my questions, but i stil lhaven't got it figured out so i thought i would ask here.
this is on my 99 turbo SS m6.
1. i have the 2 harnesses plugged into the coil packs on each side
2. i have the white wire going into one side of my momentary switch and then it continues out to a ground.
3. the grey wire is connected to pin# 32 on the blue connector of the pcm(i believe it is a grey wire).
here is my problem. i hit the momentary switch with the clutch in and it enables the 2 step, but whn i dump the clutch, it won't disable my 2 step rev limiter.
this is the only way i have found to make it work.....i tap the momen switch with the clutch in and have my set rev limit...then i hold down the momen switch again and release the switch and the clutch at the same time. i know i shouldn't have to do this but unless i hit that button again, my 2 step won't disable. any ideas?
thanks
Old Aug 14, 2002 | 07:58 PM
BLOWNMERO's Avatar
Default Re: help with 2 step install....????
have you ever dynoed your setup? If so what did you get?
Old Aug 14, 2002 | 10:29 PM
BOOSST's Avatar
nope, no dyno #'s. i did run it at the track once and got a 11.9@118 with a 1.8 60'. the air here sucks..it was over 6k that night <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" />
i have done a few things since then so i should be low 11's at a good track <img border="0" alt="[devil]" title="" src="graemlins/gr_devil.gif" />
Old Aug 15, 2002 | 11:16 PM
BOOSST's Avatar
i know several of you guys are running this 2 step...no ideas of what i should check?
