How can i git 15PSI in D1SC ?
Old Oct 10, 2005 | 08:25 AM
oOoLy's Avatar
Default How can i get 15PSI in D1SC ?
What is the S/P pulley size and crank pulley size should i buy to get 15 PSI on the procharger D1SC with 383 ?
Old Oct 10, 2005 | 01:49 PM
oOoLy's Avatar
Any help plz ... ??
Old Oct 10, 2005 | 01:55 PM
LSs1Power's Avatar
I would say 7.65 crank pulley and 3.4 SC pulley at 6400-6600RPM should get u around there Or 8.5 Crank pulley and 3.8 SC pulley and 6400-6600RPM. Every 1" increase in crank pulley = .5" decrease in SC pulley = more boost.
Old Oct 10, 2005 | 03:10 PM
oOoLy's Avatar
I have 7.65 crank pulley and 4.00 SC pulley and i only got 7 PSI ... so when i change the SC pulley to 3.4 i will get the 15 PSI ??? from where can i get the 3.4 SC pulley and how much it will cost ?
Old Oct 10, 2005 | 03:38 PM
LSs1Power's Avatar
I ran a 7.65 with 4.25 SC pulley before and saw 7.5-8psi at 6400RPM on a hot day and 8-9psi on a cold day. Boost reading will vary based on engine flow and exhaust setup. Also weather plays a big role in it. I bet you are seeing low psi readings because of the weather in your area. In your case go with 8.5 crank and 3.6 SC pulley and u will see 15psi if not more. Good luck.
Old Oct 11, 2005 | 05:56 AM
EPP's Avatar
EPP
Is this with the older 6 rib assembly or the newer 8 rib? Bob
Old Oct 11, 2005 | 06:11 AM
1dirtyZ's Avatar
habibi , make sure you have an sdce tensioner setup so you can actually be able to make the belt grip and get those numbers.
Old Oct 11, 2005 | 08:55 AM
NA$TY-TA's Avatar
I agree also...... now the smallest 8 rib pulley ATI makes is a 3.4" and they run $90 each. Now Riechard Racing makes a smaller 8 rib pulley but your going to pay for it.... they make a 3.3" and a 3.2" and they run $160 each.
Kyle
Old Oct 11, 2005 | 09:21 AM
Slowhawk's Avatar
LS1Tech Sponsor
Also matter's if you have the Crappy ATI inlet hat on the blower
Old Oct 11, 2005 | 10:31 AM
Ed Blown Vert's Avatar
Kyle
ASP just emailed me back and can make anything for $95
Old Oct 11, 2005 | 12:13 PM
oOoLy's Avatar
Thank you for your help ..... I have 8 rib pulley so now i must change my SC pulley to 3.4 ??
any one knows SDCE and ASP wep sit or e-mail ??
Old Oct 11, 2005 | 12:30 PM
www.sd-concepts.com
asp@aspracing.com
Old Oct 11, 2005 | 12:45 PM
NA$TY-TA's Avatar
I agree with that...... i made my own with the help of a friend.....
Is this with the stock twin Intercoolers still????
Kyle
Old Oct 11, 2005 | 01:41 PM
oOoLy's Avatar
yes i have the stock twin Intercoolers !! How can i know about the Crappy ATI inlet hat on the blower ????
Old Oct 12, 2005 | 05:30 AM
EPP's Avatar
EPP
Great question. Do you have the 3.5" twin intercoolers, or the new for '05 4.5" twin intercoolers with the larger 3" piping? At the very least you are going to want to use the new 4.5" intercoolers. Bob
Old Oct 12, 2005 | 06:04 AM
oOoLy's Avatar
I have the 3.5" twin intercoolers so that is a big problem ?? or can i git 15 PSI with the 3.5" twin intercoolers ??
Old Oct 12, 2005 | 10:38 AM
NA$TY-TA's Avatar
Its harder to do because there restrictive... but it can be done.....
Old Oct 12, 2005 | 10:39 AM
Bob what would it cost to switch over to them??
Old Oct 12, 2005 | 11:28 AM
ls1290's Avatar
Dumb Ass Vette Moderator
The easiest way to get 15 psi of boost is to shove a bananna in the tail pipe
Keith
