how much boost
Old Sep 11, 2002 | 08:08 AM
88ls1blazer's Avatar
Default how much boost
How much boost can you run on 8:1 compression and still run 93 on a 346 cube for the average tuner?
Old Sep 11, 2002 | 08:32 AM
AlienDroid's Avatar
Default Re: how much boost
You could probably do 18 psi on 8.0:1 on 92 octane, assuming you have a good intercooler, low overlap cam, and dish shaped pistons (8:1), normal head gaskets and reasonable weather. However 18lbs is what people seem to be able to get with 8.5:1 with a good setup but on smaller motors.
detonation <img border="0" alt="[fight]" title="" src="graemlins/gr_punch.gif" /> boost
most of the time race gas is a poor excuse for a bad/cheap setup.
Old Sep 11, 2002 | 08:50 AM
i am building the motor from scratch, i will be running modified 6.0 heads dished pistons, felpro 1041 head gaskets, stock crank, eagle h-beams, and i will have diamond pistons, and probably pro-gram billet caps, the intercooler will be approx, 26x16x4 by charged air, limited room on an s-10, and arp head studs
Old Sep 11, 2002 | 10:44 AM
DenzSS's Avatar
I'd go with the cometic gaskets. Pretty nice gaskets.
That is pretty close to what I'm building.
Old Sep 12, 2002 | 06:36 PM
well, on that note, what has everyone had the best luck with gasket wise?
