IAT Sensor Thread size???
Old Oct 11, 2005 | 04:05 PM
APD*98SS's Avatar
Default IAT Sensor Thread size???
Can anyone help me with the IAT sensor thread size for intercooler plumbing and possibly where I can get the boss from to weld it into my plumbing???
Old Oct 11, 2005 | 05:00 PM
618HAWK's Avatar
It is a 3/8-13 NPT ....AS for a boss last one I used just local hardware store or Home Depot. Used a 3/8 to 1/2 threaded bushing..
Old Oct 11, 2005 | 08:14 PM
frcefed98's Avatar
I thought it was 3/8-18 NPT? I have the spec sheet on it somewhere I'll check it out.
J
Old Oct 11, 2005 | 08:19 PM
NA$TY-TA's Avatar
J
I have one in my tool box i just saw it..... ill go look.......
Kyle
**EDIT**** Yep FRCFED is right its 3/8-18 NPT Just looked at mine.
Kyle
Old Oct 11, 2005 | 08:40 PM
frcefed98's Avatar
Yep here is the info off my Delphi spec sheet
Mechanical Characteristics
Sensor Body Material Brass Housing
Hex Size 18.90mm (3/4")
Thread Size 3/8"-18 NPTF
Sealing Pressure 200 kPa
Mating Connector & Seal 12162197
Installation Torque 20 N-m, dynamic
Overall Weight 33.3 g
You can find mounting bungs on mcmaster.com
4513K72 is the pn for the one I'm going to get if I can't find it locally.
Old Oct 11, 2005 | 09:28 PM
618HAWK's Avatar
Whoops miss read the tap, sorrry.
Old Oct 11, 2005 | 09:31 PM
frcefed98's Avatar
Its all good, I've done the same thing, figured it was a typo
Old Oct 12, 2005 | 05:13 AM
KAOS's Avatar
not to hijack but where are you putting them? on my old setup it was in the filter and never had anything to do with the turbo. should it go down stream of the turbo, like a stock setup, and allow the turbo to blow through it? just wondering what every body else is doing
Old Oct 12, 2005 | 10:36 AM
618HAWK's Avatar
Somewhere close to the MAF just before--entering the engine. Want to get the best reading of the air that is going to be used.
Old Oct 12, 2005 | 01:16 PM
KAOS's Avatar
but before the MAF right? iat then maf then engine? thanks
