overDrivenpullies
Old Sep 16, 2002 | 01:25 PM
Maxmumboom's Avatar
Default overDrivenpullies
Is there a company that makes smaller pullies out there? id like to increase the boost on my magna, but they offer only 1 pulley, whick @5800rpms makes 7lbs. i figure if i can find a smaller crank pulley I could speed up the over all drive, increasing the boost. i think im going to call whipple to se if the offer a smaller crank pulley. Is there a formula to figure out the potential boost increase from going to a smaller pulley? what size is the one from the vette, or camaro ls1? Who sells ls1edit?
01 gmc sierra 1500 SCSB
5.3L 3:73 Level 10 4l60e/2900stall/275-45-20goodyear gtII's MagnaChager\ramair intake\Jba Headers\gibson super truck catback\SuperShits tuning
Old Sep 19, 2002 | 08:52 PM
1dirtyZ's Avatar
Default Re: overDrivenpullies
it's not exactly a boost equation , but it gives you the blower's impeller(s) revloutions.
impeller speed= (crank pully diameter X max engine rpm X internal step up of blower) / blower pully size.
you could get a pretty good idea of what percentage the boost will increse after installing a pulley.
hope this helps.
Old Sep 21, 2002 | 12:47 AM
slow's Avatar
you need either a smaller blower pulley, or larger crank pulley.
ASP can custom make pulleys, so that might be an option for the blower.
you might be able to use a vortech, powerdyne, or paxon pulley, go to a local speed shop, and compare the pulleys.
Ryan.
