Vortech owners(or anyone that would know this)?
Does anyone know what the injector rated fuel pressure for the 38lb injectors that come with the kit is??
Also does anyone know what our fuel rail pressure is??
Thanks Jason
Thanks Jason
Re: Vortech owners(or anyone that would know this)?
The Injectors Are Lucas 38lb. (They Are 38lb At 44psi). The Returnless Style Fuel Systems Run At About 60psi. This Means That The Injectors Are Actually Flowing That Of An 52lb. Injector. Here Is The Formula New Flow Rating=[Square Root Of(60psi/44psi)]x38lbs./Hr=52
The Injectors Are Lucas 38lb. (They Are 38lb At 44psi). The Returnless Style Fuel Systems Run At About 60psi. This Means That The Injectors Are Actually Flowing That Of An 52lb. Injector. Here Is The Formula New Flow Rating=[Square Root Of(60psi/44psi)]x38lbs./Hr=52lb
