What are u guys doing when the mass air gets maxed out.
The market was asked to gauge interest in them on here and other UBB's and response was low. I guess no one minded the 58.1lb limit. Do a search, you will find the post.
Scott if you need one, drop me an email.
If Pro-M is prototyping, then GMS should have a unit out shortly.
My biggest issue now is frequency range, thus the new proto-MAF <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> I'm hitting the 12 kHz barrier on the stock MAF, so extending the table does me no good.
too bad the car is down right now, i'd have data already <img border="0" title="" alt="[Sad]" src="gr_sad.gif" />
Now getting the tune happy is the trick, stratagically placed factors of 2 can do wonders.
<strong>generally speaking, 68 lb/min should get you 680hp at the flywheel. Probably close to 650 RWHP.
Now getting the tune happy is the trick, stratagically placed factors of 2 can do wonders.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Harlan, if you are not concerned about low frequency granularity (some accuracy), you can extend the MAF not to hit the 12hz limit before you hit the PCM's 512g/sec. The MAF is the EASY part, the PCM limit (512g/sec)is the hard part.
So we( Me and JAS) reworked the meter electronically to match the new table.Works very good.
I have a 98 f-body and 11250hz is the limit.
Newer pcms can go up to 12khz but your still stuck with 511.99 gms/sec.
I was hitting 65lbs/min on my last motor.
Have not boosted it up that high yet on this motor so I don't have current readings.
But 67lbs/min means some pretty strong power to the wheels.
Steve
<strong>Harlan, if you are not concerned about low frequency granularity (some accuracy), you can extend the MAF not to hit the 12hz limit before you hit the PCM's 512g/sec. The MAF is the EASY part, the PCM limit (512g/sec)is the hard part.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">That's where a .5 multiplier on some things and a 2 multiplier on others comes in. I was flowing about 75 lb/min through the stocker before i hit 12+ kHz limit. I can't read any more at that point, thus the new MAF
The new one hits about 1200 g/s at 12 kHz <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" />
but my target range will keep me under 10 kHz, about 800 g/s <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Too bad the motor went south, but i got my donor shortblock today, so it'll be running soon
<strong> </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by JAS:
Too bad the motor went south, but i got my donor shortblock today, so it'll be running soon</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Harlan - You say you were flowing "about" 75lbs. I'm willing to bet that's not what the log file says. <img border="0" title="" alt="[Razz]" src="gr_tounge.gif" /> Don't get me wrong, I DO believe you achieved it, but the log only says 512g/sec @ 12kHz. <img border="0" alt="[angel]" title="" src="graemlins/gr_angel.gif" />
Your still bound by the 511.99 limit. (You know this, unless it's been 'rewritten' <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> ) I'm guessing your splitting or under reporting the MAF, just as a ported MAF does... in a way. Then to achieve proper load values, you are doubling the PCM stuff to achieve 100% load value usage at 50% reported. So, when your reporting 512g/sec on proper tune MAF, with a split version, it would report 256g/sec. At this point I would really be concerned about the accuracy of the MAF unit. I don't see an LS1 pulling 134lbs anytime soon so with a little more math, a calibration to your needs is a better idea than jumping to 1024g/sec. It's late, I might of might of missed something, but I know that you know what I mean.
Now if we could only convince you to quit using the blow through method. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
<img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
<small>[ October 03, 2002, 01:32 AM: Message edited by: JAS ]</small>
<small>[ October 03, 2002, 10:12 AM: Message edited by: scott ws6 ]</small>
It works OK but resoloution sucks when you cut it in half or less.
I used to see maybe 24lbs maf flow peak reported but was t well over 40 in reality, That was NA of course..
Steve
