pulley size for Vortech
Just a question to see who knows. I have the Vortech V-9 kit and it has the 3.125 pulley on it. Is this the 6lb pulley or what. I only see about 5.5 at WOT. Can I get a different pulley to help here and what is the next size offered?
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Chad00ws6:
<strong>Just a question to see who knows. I have the Vortech V-9 kit and it has the 3.125 pulley on it. Is this the 6lb pulley or what. I only see about 5.5 at WOT. Can I get a different pulley to help here and what is the next size offered?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Yes...you can get a smaller pulley for it. ASP has pulley's for that kit. After buying a 2.95,2.85 an finally a 2.75 pulley. I finally went with 2.75 pulley...so I am seeing close to 11 lbs of boost.
Jason
Jason
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif"> Originally posted by SuperchargedZ:
Yes...you can get a smaller pulley for it. ASP has pulley's for that kit. After buying a 2.95,2.85 an finally a 2.75 pulley. I finally went with 2.75 pulley...so I am seeing close to 11 lbs of boost. </font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">How much did each pulley give you and are you running 11lbs on stock internals? <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" />
I just want 7-8 which one should I go with? Also did you also have about 5.5 with the 3.125 pulley?
Wanna sell your others? <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
<small>[ October 06, 2002, 10:46 PM: Message edited by: Chad00ws6 ]</small>
[/b][/QUOTE]How much did each pulley give you and are you running 11lbs on stock internals? <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" />
Wanna sell your others? <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> [/qb][/QUOTE]
Each gives you about 1-2 lbs of boost increase. If you want 7-8, you should go with the 2.85 pulley.
The pulley's are pretty cheap. About 75 bucks each.
Jason
<small>[ October 06, 2002, 11:07 PM: Message edited by: superchargedZ ]</small>
Jason
Chad, there is someone at the shootout that you may want to talk to. He has talked to Vortech about their V9-G-Trim unit blowing up over 8psi or so of boost.
Also, will they warranty your unit if it blows up on higher levels of boost than stock?
See ya at the shootout!
I have been over spinning the **** out of it. I have the 2.75" pulley and rev limiter at 7100. I'm spinning the blower about 10,000rpms faster than vortech says it can handle. I have been doing it for about a year. I was having a problem with oil in the tubes until I but on the BOV.
Vortech warranty drops from 3 years to 1 year with a different pulley.
