8 rib ATI question
Old Oct 7, 2002 | 01:16 AM
1dirtyZ's Avatar
Default 8 rib ATI question
if any one out there is running an ATI 8 rib setup , how wide was your tensioner pulley?? was it wider than the 8 rib belt?
did the pulley come with or without the axle thingy that goes through the pulley?? ( the peice of metal that the tensioning bolt pushes on and has a bolt on the other side to lock it to the bracket)
thanks
Old Oct 7, 2002 | 01:56 PM
Black LS1 T/A's Avatar
Moderator
Default Re: 8 rib ATI question
Why don't you find one of Clay Loving's posts and email him. I think he was/is on an 8-rib setup. He may be going to a cog.
Old Oct 7, 2002 | 04:18 PM
1dirtyZ's Avatar
thanks mike,
i called ATI and it seems i been sent the wrong tensioner pulley, it was for a 12 rib setup! (sorta explained why the belt only covered 2/3 of the pulley)
Old Oct 7, 2002 | 05:48 PM
SuperSport2000's Avatar
Ati's 12rib idler is the same idler they use for a 8rib application. I machined the idler now my 8 rib works great.
Old Oct 7, 2002 | 08:49 PM
1dirtyZ's Avatar
hey SS2000, which end of the idler pulley did you machine , and by how much?
thanks
Old Oct 8, 2002 | 01:16 AM
I machined both ends. Can't tell you how much because I didn't measure it. I just took enough off so it would fit.
