Building FI motor, NEED Help
Old Oct 26, 2002 | 08:23 PM
NOS powered LS1's Avatar
Default Building FI motor, NEED Help
I need to know everything I need to run 10-12 lbs. of boost safely, here is what I have came up with so far
1. JE Forged Pistons 9:1 CR
2. Oliver forged Rods
3. ARP Rod Bolts
4. Piston Rings
5. Bearings (which kind)?
I know where to get #1,2,3.....where can I purchase #4,5?
Old Oct 28, 2002 | 08:44 PM
Cool28's Avatar
Tire Smoking Tranny Blowing Director
Default Re: Building FI motor, NEED Help
TTT
Old Oct 28, 2002 | 10:59 PM
MIGHTYMOUSE's Avatar
-a forced induction kit
-correct tuning (edit/dfi/fast/custom)
-fuel system (minimum of one gss340 in tank and 42# svo injectors, aftermarket pressure regulator)
-drivetrain upgrades like rear, trans or clutch, maybe a driveshaft.
if i were you i would shoot for output rather than boost level, they do not go hand in hand.
i ran 10psi on an all stock motor and it was fine (for a while).. but that was because it was a very small turbo and didn't flow much air.. follow me?
Old Oct 29, 2002 | 07:52 PM
1dirtyZ's Avatar
head gaskets, i recomend cometic.they come oringed for more sealingand in any thickness as well as being reusable!
