ATI belt slip
Old Oct 31, 2002 | 11:10 AM
White SS's Avatar
Default ATI belt slip
in wot at about 3k I'm seeing about 4psi and by 6k im only seeing about 2psi does this meen that my belt is slipping?
how can I fix the problem?
also my belt is not loose
Old Oct 31, 2002 | 11:43 AM
1dirtyZ's Avatar
Default Re: ATI belt slip
first off all check the crank balancer bolt it could be loose.
and how do you know that your belt is tight? it needs to be very tight(tight as in it rings when you tap it). check for dust around the blower pulley.
i also use belt dressing (you can find it in any auto store) which really helped my slippage issues.
you could also check that all hose clamps are tight.
where did you tap the boost guage?
Old Oct 31, 2002 | 09:29 PM
1dirtyZ's Avatar
i keep hearing bad things about aftermarket maf's and F/I.
what i did on the dyno was to richen the car alot at the top end using the p/e tables.
if all else fails use the injector flow rate chart to richen up the top end. just change the last box to a smaller number .
hope this helps.
Old Nov 1, 2002 | 12:35 AM
White SS's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by 1dirtyZ:
<strong>i also use belt dressing (you can find it in any auto store) which really helped my slippage issues.
</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Worked! <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
But new problem slp maf maxed out <img border="0" title="" alt="[Sad]" src="gr_sad.gif" />
just put it on two days ago should I reset pcm?
<small>[ October 31, 2002, 12:36 PM: Message edited by: White SS ]</small>
