F/I options
Old Oct 16, 2005 | 02:20 AM
RDeputy150's Avatar
Default F/I options
After reading more than my tired eyes can handle, I have a simple question for you F/I gurus regarding the direction I should go for my car (00 T/A, A4, completely unmodded to this point).
Here's what I'm lookin for: power under the curve. This car is my baby and is only driven in good weather, on the weekends, etc... I would like to be somewhere in the 11's when all is said and done (including suspension, engine, tranny, etc.) From what I have read, it seems the options that I personally like are a single turbo or a Vortech setup (possibly with a T trim). I don't want to go overboard with the project, something I could handle myself and would like it to be reliable (e.g. worry free). Which of these would be my best course of action? Thanks in advance.
Old Oct 16, 2005 | 02:57 AM
BAD ASS TA WS6's Avatar
BMW ///M Nerd
If you want to go F/I you're just costing yourself more if your only goal is 11s.
If all your looking for is mean street car, I say go heads and cam. This way you save yourself some cash, and you can do it all yourself.
We all know how things go though. You say you only want 11s now, once you're there, it's always more, more, more.
Just my piece of advice
Old Oct 16, 2005 | 12:12 PM
Zangel's Avatar
Fiery Features Director
If you really want to go with a turbo, I would suggest something mild like the STS kit. However, with your goals, you could simply slap on some nitrous or do heads and a cam to reach the same goal. Sometime in the future, it is very likely that you will have to rebuild the A4 with 400+ rwhp. I would suggest a converter, gears, cam, heads, headers/exhaust, and a few small suspension mods (subframe connectors, control arms, etc). These mods would easily put you into the 11's and would remain reliable for a lot less. You just have to decide if you want to go with F/I because it is different or do you just want to get into the 11's?
Old Oct 17, 2005 | 04:25 AM
RDeputy150's Avatar
Thanks for the comments so far. I'm pretty sure I want to go the F/I route, not a big fan of nitrous and the possibility of running lean and messing up the motor. Plus I do not want to have to worry if the bottle is full, how's the pressure, the temp, etc... sounds like too much of a daily headache. This is not to say that in the future I won't put a small dry shot on just for sh_ts and giggles, but I think the F/I route is the way to go.
I would match the power adder with appropriate suspension and transmission work (what exactly would need to be done to the tranny, built up as is, or replaced with a TH400 or something like that?). And a converter is certainly on the list of got-a-get things - still have to decide on the amount of stall...
And.. you guys are probably right, I probably will want more down the line, maybe a realistic goal of mid 10's, very low 11's sound reasonable?
Old Oct 17, 2005 | 05:05 AM
Assassin's Avatar
first decide how much you want to spend, that'll tell you what your 1/4 et is going to be...... and if going fi, just go ahead and x2....
Old Oct 17, 2005 | 05:27 AM
EPP's Avatar
EPP
For $1,7500.00, Rodney at RPM Transmissions can rebuild your 4L60E into a powerful tranny that can hold a lot of power. Coupled with a Neal Chance torque converter, you would have a very stout combination.
Here is a list of items that I recently put together for building up the chassis prior to adding the horsepower. People are always asking the question of whether to go with a head and cam package, or go with a supercharger or turbocharger. There is no way you are to match the power of an ATI ProCharger with a head and cam package unless you use a pretty radical camshaft. Nitrous oxide could be used instead of going the forced induction route, with very good results at a fraction of the cost. A cold air kit would be required if you elect to use nitrous oxide instead of going the forced induction (ATI ProCharger) route. The ATI ProChargers come with a K&N cone filter. With forced induction, such as the ATI ProCharger, the power is always going to be there when you want it, with no nitrous bottles to constantly refill. A turbocharger could be used instead of an ATI ProCharger, but I am not convinced that the turbo kits currently out on the market will stand the test of time. TurboChargers go through extreme heat cycles, which can fracture the turbo housing mounts.
With the items listed below, your car would be quite capable of routinely running low eleven second 1/4 mile times, or faster, when combined with the M/T Street radial rear tires.
Everyone has their opinions on what is the best package, and here is mine.
1. Subframe Connectors - Absolutely necessary to keep your F Body from twisting and stretching. I have seen too many of these cars lose their door to fender gaps from having gone too long without subframe connectors. Subframe connectors will make the car handle better, you'll get fewer squeaks and the car will get better traction.
2. Torque Arm - BMR, Global West and Spohn all make torque arms that relocate the front mount off of the transmission by relocating the front mount back behind the transmission. The relocation of the front mount relieves the stress from the tailshaft of the transmission that the torque arm places on it, as a result of trying to contain the rear-end and it's rotational stresses. The stock torque arm is a stamped piece of sheetmetal that has broken apart for many people, and it sometimes takes out the driveshaft with it when it goes. By relocating the front mount of the torque arm behind the transmission, the geometry of the rear suspension becomes much better and really aids in hooking up the rear suspension. While replacing the torque arm, check the transmission mount, as the stock torque arm places a huge load on the mount, and the mount breaks quite often when using the factory torque arm. The adjustability of these aftermarket torque arms allows the user to adjust the pinion angle of the rear suspension which aids in finding traction.
3. Moser 12 bolt - Sooner or later the weak 7.5" Chevy S-10 derived 10 bolt is going to break. I wouldn't waste any money into attempting to build up the 10 bolt, it just doesn't work. There isn't one strong point to the stocker. For those of you with a six speed transmission, the 10 bolt has broken on many M6 cars with stock power. Expect the worse to happen... 3:73 gears in the Moser rear-end is a good compromise, especially when adding a lot of power to the engine.
4. Driveshaft - The stock GM driveshaft have broken for many enthusiast, both the steel and the 3.0" aluminum GM driveshafts are fairly weak. I recommend an aftermarket 3.5" aluminum driveshaft with a 1350 Yoke with a 1350 U Joint. Combined with the Moser 12 bolt with their supplied 1350 yoke, you will have a strong drivetrain.
5. Clutch and pressure plate - I recommend the Spec Stage 3 clutch and pressure plate. Expect some chatter for the first 500 miles, then it will be pretty smooth. I would also add the '01-'02 slave cylinder for the older models, and do the "drill mod" to the master cylinder. Do a search on this forum for the drill mod, and you will see what it entails.
At this point I believe the suspension is capable off supporting a lot of horsepower, and you can go straight to item 14.
For those of you who are dragstrip bound, I would also add a few additional items.
6. Adjustable lower control arms - The aftermarket lower control arms are much stouter, and will not flex like the factory lower control arms. Going with adjustable ones will allow the user to center the rear end in the wheelwell. The stock rear end position from the factory tends to be .5" towards the rear of the car. You really won't notice it until larger diameter tires are installed.
7. Lower control arm relocation brackets - Lower control arm relocation brackets are meant to be used when the car has been lowered, which alters the angle of the lower control arms. We have found that the relocation brackets also help in getting traction in non lowered cars. We use the weld on style that BMR offers.
8. Panhard bar - The factory pan hard bar is pretty flimsy and additional traction can be found by replacing the factory pan hard bar with a heavier duty aftermarket bar. The rear in these cars tends to sit closer to the right side, and by purchasing an adjustable pan hard bar, the rear-end can be centered in the body.
9. Strut Tower Brace - Eliminate flexing in the front end by adding an aftermarket strut tower brace. You will also notice that the car will handle better with a strut tower brace.
10. Battery box relocation - By relocating the battery to the trunk, you will remove a lot of weight off the front of the car and place the weight behind the rear-end, where it will aid in traction. The car will also be able to handle better with the weight relocation.
11. Rear coil spring air bags - By experimenting with adding more air to the right air bag than to the left one, better off the line traction can be found.
12. Adjustable shocks and front coil over springs - We use the Hal QA1 12 way adjustable shocks on our cars. It is easy to adjust these shocks for street use, and then readjust them for strip use by simply rotating the 12 way adjustable dial. The Hal QA1 front coil over springs allows the front end height to easily be adjusted.
13. K member - By replacing the front K member and upper and lower control arms with light weight aftermarket tubular ones, a lot of weight is removed from the front suspension. Since front end weight is removed, better off the line traction and better handling will occur. We have had good success with the BMR parts, and combined with the Hal QA1 shocks and coil over front springs, gives the car a much better chance of getting traction on the starting line.
14. Headers and cat back exhaust - Everyone has their favorites, but we have grown very fond of Hooker and Flowtech headers, and the Hooker and Magnaflow Cat Back exhaust systems.
Flowtech and Hooker ceramic coated headers fit very well, with excellent ground clearance. The Flowtech headers are priced very competitively with PaceSetter headers, yet they install and fit much better. The ceramic coatings go a long way towards keeping the exhaust temps in the pipes, keeping the engine bay cooler and improving internal exhaust scavenging. These two brands of headers will give you 2.5" more in ground clearance compared to SLP headers.
The Hooker and Magnaflow cat back exhaust systems give these cars a good muscular sound that will not drown out your stereo while driving down the road. The exhaust tubing is larger than the stock tubing and is mandrel bent, for better exhaust flow.
For those of you who want it loud. If you are looking for an exhaust system that will annoy everyone around you, the two above exhaust systems are not for you. The SLP "Loud Mouth" cat back is a good system for those of you who want to be noticed. When we have one of these cars on my dyno with a loud mouth exhaust system, everyone around our area can hear the car!
15. ATI ProCharger D-1SC eight rib supercharger - Simply the best and easiest way to get 450 to 500 rwhp out of your car in my opinion, when combined with headers and a good cat back exhaust system. The car will still see great part throttle gas mileage, overall driveability will still be excellent, and the power is always there when you want it. At 8 pounds of boost, the car will be very dependable, and with the twin high flow air to air intercoolers, unleaded premium is all you need to use. I recommend the ATI ProCharger D-1SC "tuner" kit, as the D-1SC can handle future mods much better than the P-1SC. You will need 42 lb fuel injectors, a 255 litre in tank fuel pump, and chassis dyno tuning with the "tuner" kit.
Hopefully this list will help you in your quest for having a quick car! Bob
Old Oct 17, 2005 | 06:34 AM
Got Me SOM's Avatar
A vortech with a G trim will get you into the 11's easy. A T trim is nice but I recommend getting it with a front mount intercooler cause the aftercooler isn't rated to handle the extra cfm's. If you do still want the T trim you should get your short block built. Get a nice stall (3500) with a transgo shift kit and a tranny cooler.
Basic bolt ons like a headers and a good exhaust will all that'll be needed.
All the suspension items are nice but not needed. A set of lower control arms and relo brackets will help push the tires down. A sticky tire like the Mickey Thompson will get you to hook. If its just your occasional weekend car, you don't have to spend a ton of cash and most certainly don't need all the parts that the person above just listed..
Old Oct 17, 2005 | 07:29 AM
Zangel's Avatar
I definately agree with you on that one!
Old Oct 17, 2005 | 08:50 AM
White.Lightning's Avatar
Your budget is the first decision and that directly affects your HP goals. I couldn't have said the above quote any better!
Good luck
Andy
Old Oct 18, 2005 | 03:16 PM
RDeputy150's Avatar
Ya, I definitely know the budget could be the limiting factor. I'm the type that will save up for something and do it right the first time, so basically whatever will be best for my application is what I want to do, despite the cost. Thanks for the help so far!
Old Oct 18, 2005 | 03:32 PM
99SS-T's Avatar
If you plan on goin 10's its gonan cost ALOT more then jsut gettin into the 11's.
Turbo kit is 4500, fuel is 1500, engine is 3k, heads 2k, cam oil pump timing set 600, tranny 2500, torq verter 600, rearend is 2200, cage is 1k withou install suspension if 1500, rims tires 1k. the list never ends.
ORRR you coudl jstu go 11.75 with heads cam enhaust and a small shot.
Ya said that you wanna use it on nice days and the weekend and to spend 20k to do that is crazy when ya can spend 4k and blow the rest on hats......
John
Old Oct 18, 2005 | 04:57 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
To go 10.9 with a Vortech you can get with the base head unit, don't need a T-Trim. I'd shoot for 500rwhp to hit 10.9.
Old Oct 25, 2005 | 10:29 PM
ATLHwyRacer's Avatar
very good post!
