Why T-trim?
Old Jan 1, 2003 | 11:21 AM
stealth's Avatar
Default Re: Why T-trim?
I bought a YS-trim and will let you know how to works.
Old Jan 1, 2003 | 11:26 AM
30thta436's Avatar
Please keep me updated stealth. thanks
Old Jan 1, 2003 | 06:12 PM
Jackyl_30's Avatar
I also called Vortech and the core on the aftercooler is the same with all Vortech kits. They say you may loose a pound or two with it unless you get their Mondo cooler which will not fit in our cars. So I am not too concerned with the aftercooler.
Old Jan 1, 2003 | 06:18 PM
MelloYellow's Avatar
Talked to a SC Tuner and they mentioned cfm flow limits on the aftercooler should only affect top end rpm boost and it should be at a minimum.
When would you see 1200cfm at 10psi? 20psi?
The T-Trim would definitely improve low and mid range boost in any case.
Old Jan 1, 2003 | 08:00 PM
Jackyl_30's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by MelloYellow:
<strong> Talked to a SC Tuner and they mentioned cfm flow limits on the aftercooler should only affect top end rpm boost and it should be at a minimum.
The T-Trim would definitely improve low and mid range boost in any case. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I agree.
Old Jan 2, 2003 | 08:24 PM
VINCE's Avatar
Shorty Director
You are saying that the only need for the T-Trim is to increase midrange power? Like the F1-SC blower is to the ATI crew?
Old Jan 6, 2003 | 08:19 PM
2bseen's Avatar
11 Second Truck Club
To those who are running the t-trim what did it cost what changes did you make to get it installed I am asking this b/c I can't get over 5# boost b/c of slipping the belt above 4500rpms. Btw I am running the small pulley trying to get more boost.
Old Jan 6, 2003 | 11:09 PM
Jackyl_30's Avatar
Since you already have the kit all you would need would be the brackets and the head unit. Since I got mine all at once and never had a kit to begin with it was a little more for me.
Vince- All I know is I get 5psi almost instantly and it goes up REAL fast from there to 13or 14psi. From what I hear that does not happen with a G trim. (since I never had a G trim)
Old Jan 7, 2003 | 01:18 AM
VINCE's Avatar
Shorty Director
Instantly is good.. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
