ATI stage II blower w/custom fuel system???
I am running the P1 w/42 lb injectors... I am running the Aeromotive A1000 fuel pump and the Aeromotive Fuel Pump Controller.
vetterdstr <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Spectra Aeromotive Eliminator pump , it is bigger then the A1000. I have the LS1 speed Inc. tank with the built in sump, a filter then the pump then another filter the dash 8. I have the aeromotive regulator also. I made my system returable. I also have bosch 50 lb inj
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by scott ws6:
<strong>Spectra Aeromotive Eliminator pump , it is bigger then the A1000. I have the LS1 speed Inc. tank with the built in sump, a filter then the pump then another filter the dash 8. I have the aeromotive regulator also. I made my system returable. I also have bosch 50 lb inj</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">scott ws6 , sorry for not answering sooner. Thanks ,I appreciate your help.Where did you buy your tank? Where did you install the regulator and what kind of fuel pressure are you seeing(cruise and WOT)? I want to start from scatch and redo my fuel system ,but would like to keep the stock tank. I would like to run two lines in parallel ,replacing the intank pump with maybe a walbro 255 and have the a1000 on the other line ,turning on only under boost. What do you think about a fuel pump controller/ digital FMU from Aeromotive? Thanks again. <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
The tank I got is from www.ls1speed.com I mounted the regulator on the driver side on the wall in front of the fuel rail. because that is where I run the return. -4 from the rail to the regulator, then -6 back to the tank. Il have to ask julio at cartek what the pressure is at.
Did you also get the fuel rails from LS1 Speed Inc.? What size are your rails and your return line? Sounds like you have a very efficient fuel system and is very happy with it. I have a lot of work ahead of me. Do you know who carries a Walbro 255lph intank pump? I can only find a Granatelli 255lph and a Holley both from Summit.What do you think about them? So If keep the stock tank I should get rid of the stock intank regulator and get the Aeromotive regulator installed on the fuel rail with a return line ?Thanks.
