Aluminum vs Iron Block for Forced Induction?
Go here
https://ls1tech.com/ubb/ultimatebb.p...c;f=1;t=008873
I chose to go with an Iron Block for the 422 buildup, because at some point I see close to 700 RWHP if I can ever get the fueling in place. DEFINITELY, I see an Iron Block or the C5R Aluminum block as a neccesity for anyone who may want RWHP in the mid-600's or higher.
You could get the BMR K-member and associated hardware and drop 100 pounds from your front, if you decide you require the Iron Block.
Again, I just don't see the difference between 346 and 366 CID gaining you anything. I'd prefer the Aluminum block up to a 382/383 CID, myself. Only after exceeding that would I worry about the Iron Block option. Then, if I had the money, I'd do the C5R. Otherwise, I'd go to the overbore/stroke on the Iron Block.
My 2cents. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Until i physically split the block from excessive power, i will continue to run an aluminum block
<img border="0" alt="[judgement]" title="" src="graemlins/gr_judge.gif" />
Just an opinion <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
