how much boost?
Old Nov 14, 2002 | 02:59 PM
White SS's Avatar
Default how much boost?
also how much rwhp should be expected from m6
d-1sc 3.4 pulley
slp heders
!cats
slp "y" pipe
3" cutout
corsa catback
ls6 intake
80mm throttle body
slp maf
6.0L ported heads unmilled
comp 224/228 114lsa 588lift
Old Nov 14, 2002 | 08:53 PM
MIGHTYMOUSE's Avatar
Default Re: how much boost?
i would never 'expect' to have a certain number, it depends on too many things.
i think that head unit is capable of around 800 rear wheel (i think) flow wise but you will never see that with a stock bottom end./compression.
i don't know if that pulley will work or not but the limit for fi, intercooled stock engine cars seems to be over 500rwhp now, but not on pump gas..
Old Nov 14, 2002 | 09:24 PM
scottywheels's Avatar
The D1 is good to 950 hp however with your set up I would think around 525-550 is not out of the question. Ive seen cars with the 3.2 pulley and a cam with other bolt ons but no heads make 587rwhp.
Old Nov 16, 2002 | 08:06 PM
White SS's Avatar
ttt
