PAGING BLACK LS1 T/A
Old Nov 16, 2002 | 03:57 AM
spectra57's Avatar
Default PAGING BLACK LS1 T/A
Do you still have your stock in-tank pump and stock Regulator? How about the in-line pump from ATI's stage I kit? Are you also using it plus the Aeromotive pump controlled by boost? How many pumps are you using and how are they connected(series/parallel)? Just want to get this right. Seems your the only one with a close set up that works. I have ATI's P-1SC w/42lb injectors and the 3.20 in. pulley. Thanks.
Old Nov 17, 2002 | 12:37 AM
scottywheels's Avatar
Default Re: PAGING BLACK LS1 T/A
spectra I ran your set up last year with just the booster pump and had no problems at all. I left a message for you on your fuel sys question about my set up now. and the pump I use
<small>[ November 17, 2002, 12:38 AM: Message edited by: scott ws6 ]</small>
Old Nov 17, 2002 | 08:27 AM
Black LS1 T/A's Avatar
Moderator
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by spectra57:
<strong>Do you still have your stock in-tank pump and stock Regulator? How about the in-line pump from ATI's stage I kit? Are you also using it plus the Aeromotive pump controlled by boost? How many pumps are you using and how are they connected(series/parallel)? Just want to get this right. Seems your the only one with a close set up that works. I have ATI's P-1SC w/42lb injectors and the 3.20 in. pulley. Thanks.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Sorry for slow answers this weekend... I'm singing in Tallahasse, FL this weekend and am logging in at the hotel right now.
I'm using Golden West Performance's solution:
Aeromotive Eliminator Pump (turned on only at bost) in series with my stock pump. It's worked since I bought the kit August of 2001. But, I am looking at taking it to parallel with this 422.
I, too, ran 42# injectors with the 3.20" pulley. But, I plan to change injectors soon for the 422. I hav the D-1SC compressor.
These links on my site's 'Tech' page may be helpful:
http://blackls1ta.com/tech_files.htm
Old Nov 18, 2002 | 04:19 AM
spectra57's Avatar
thanks black LS1 T/A, You don't think the A1000 is strong enough?
Old Nov 18, 2002 | 05:56 AM
Moderator
Yes, it is. But, the Eliminator has some unique properties that make the in-line solution doable. The A1000 may have issues as an in-line pump.
It doesn't hurt that the Eliminator DOES have more flow capability, but that is not the primary reason.
