whats the diference between the gss340 and the gss307
Old Nov 23, 2002 | 06:24 PM
parish8's Avatar
single digit dreamer
Default whats the diference between the gss340 and the gss307
i just got a pump in the mail, i thought i was geting the gss340(255L/hr) pump that everyone talks about but i actualy got a gss307(still a 255L pump). what is the diference, should i send it back and get the 340?
Old Nov 23, 2002 | 06:59 PM
parish8's Avatar
Default Re: whats the diference between the gss340 and the gss307
ok, i guess i will answer my own question but i have a new one also, here http://www.gnttype.org/techarea/fuel...albroflow.html i found some flow graphs of various pumps, it shows the 340 and the 307 about the same at 60psi, it also shows them at only 50gph. thats not going to get it done, on another page it shows the flow at 57gph at 13.5v. lets say i go with the 57gph, i don't think that is going to get it done.
right now i have 41lb@58psi injectors, that works out to be 55gal/hr. and i maxing those injectors out.
so my new question is, is there a single intake pump that i can toss in there that will flow more like 80gph?
Old Nov 25, 2002 | 04:42 PM
MIGHTYMOUSE's Avatar
it is always a good idea to throw a relay in the stock wiring and bring a hot wire from the battery to run your pump at 14 volts instead of the stock voltage which is regulated around 12
i have measured mine to be 14.11 volts to each of my pumps.
if you paid for a 340 and got a 307 i think its worth your time to send it back and get what you paid for.
what kind of power you looking for? a single gss340 will support 550rw FI
