Cheat Sheet for High Octane
Old Nov 15, 2002 | 02:07 PM
SJH's Avatar
SJH
Default Re: Cheat Sheet for High Octane
toulene is some serious stuff. From what I understand it is the better fuel to use than xylene even though it's octane is a tad lower.I can't remember why though.
F1 cars used to run pure toulene with enough heptane added to LOWER the octane rating to meet the octane specs.
They used to run 70psi back in the days when turbo f1 was allowed, making incredible power on that blend.Without the toulene blend it was not possible.
Toulene works better than any other booster I have ever tried.
I usually toss 2 gallons to 5 gals 93.
<small>[ November 15, 2002, 02:09 PM: Message edited by: SJH ]</small>
Old Nov 15, 2002 | 04:36 PM
AzzHauler's Avatar
From: Richmond, VA Where fast cars, well......are hard to come by.
Ahhh! I keep going back to bookmarked sites and read about it, but never actually mixed any. Now I have a nice little spreadsheet with it. WTG.
Old Nov 16, 2002 | 12:56 AM
Reckless's Avatar
Super Moderator
Default Cheat Sheet for High Octane
Little something I made up when I was turbocharged. Just get some Xylene or Toulene and your ready to go!
www.turbo-ws6.com/racegas.xls
Old Nov 17, 2002 | 02:49 PM
bofrcNoir's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by SJH:
[QB]toulene is some serious stuff. From what I understand it is the better fuel to use than xylene even though it's octane is a tad lower.I can't remember why thoug.</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Very very expensive to obtain pure xylene. When you buy it at the hardware or chem. store it's usually a mixture of others chem. because it's hard to isolate it. The octane rating is for pure xylene, the one you buy i.e. the mixture is diff. & the other chem. present in the mix. may be harmful to your engine, cats, etc...
Toluene is a safer bet.
Old Nov 17, 2002 | 02:53 PM
parish8's Avatar
single digit dreamer
where did you get that info on zylene, i have been runing some thru my engine and if it is a bad thing i will have to switch to toluene. i have no cats so that part isn't an issure.
thanks
Old Nov 17, 2002 | 03:10 PM
Importdestroyer's Avatar
Hey Reckless, where did you buy your Touelene/Xylene from over here? I heard its expensive. And I cant access your cheat sheet, what is the ratio of toulene to gas? And how fast were you going through O2 sensors?
Old Nov 17, 2002 | 06:48 PM
bofrcNoir's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by parish8:
<strong>where did you get that info on zylene, i have been runing some thru my engine and if it is a bad thing i will have to switch to toluene. i have no cats so that part isn't an issure.
thanks</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Way back in my organic chem. class <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
I recently read the same in an article about octane booster, I believe it's at Idaho corvette.
Anyway, I use about 15% Toluene w/ my 7lbs ATI setup in my C5, seems to take care of the occasional pigging when it's hot outside.
Old Nov 18, 2002 | 08:42 AM
Reckless's Avatar
Super Moderator
HP...you could buy the stuff in the paint section at Kilgo's on Sand Island. Just about any paint supply store has it. Home Depot didn't have it though. Does not harm your O2 sensors.
Net Oct...Gals 92 Oct...Gals of Toulene...Net Gals
95.6...........5..............1..............6
96.4...........4..............1..............5
97.5...........3..............1..............4
98.3...........5..............2..............7
99.3...........2..............1..............3
99.3...........4..............2..............6
100.3..........5..............3..............8
100.4..........3..............2..............5
101.4..........4..............3..............7
101.8..........5..............4..............9
103............1..............1..............2
103............2..............2..............4
103...........2.5............2.5.............5
103............3..............3..............6
103............4..............4..............8
103............5..............5.............10
105.2..........2..............3..............5
106.7..........2..............4..............6
107.7..........2..............5..............7
109.6..........1..............4..............5
110.3..........1..............5..............6
Todd
<small>[ November 18, 2002, 08:49 AM: Message edited by: Reckless ]</small>
Old Nov 18, 2002 | 02:23 PM
ChevyNo1's Avatar
How does Toluene compare to say, Torco? I've used that with 7psi mixed with 91 octane and I have no KR. That stuff works great. I've run Toluene once . . . it's damn expensive here in AZ at the paint stores!!!
- Dug
Old Nov 18, 2002 | 04:51 PM
SS00Blue's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by ChevyNo1:
<strong>How does Toluene compare to say, Torco? I've used that with 7psi mixed with 91 octane and I have no KR. That stuff works great. I've run Toluene once . . . it's damn expensive here in AZ at the paint stores!!!
- Dug</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Toluene and Xylene have been my way to high Octane for years. I have installed paint systems for 15 years. Right now I am involved in painting the Vipers for DCX. Those chemicals are used for paint thinners...
And they're a great head-rush, too! <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old Nov 18, 2002 | 05:11 PM
DaveSchott's Avatar
SS00Blue: You've got a PM...
Old Nov 25, 2002 | 05:28 PM
gnx7's Avatar
whether you mix Tuolene or Xylene you should not use more than 30% in your mix. Also add 2 ounces of Marvel Mystery Oil (MMO) as the additives that the gas manufacturer's add need to be added back in for proper piston ring lubrication.
We turbobuick (GN/TType) have been using this for years.
3 gallons Xylene (117 octane)
7 gallons of 92 octane
2 ounces MMO
99.5 octane! (slight savings vs. buying 100 octane from a race fuel distributor)
Or.....
7 gallons 100 octane unleaded
2 ounces MMO
105.1 octane unleaded!
