In-line Booster Fuel Pump
How much fuel pressure is seen with what mods and does it help? Planning a 4psi turbo and wondering if I need a fuel pressure boost.
stock fuel pressure (60) is more than enough, what you need is flow, hotwireing your stock pump with a direct +12 lead and a relay should get you safety at ONLY 4psi, no more.
after that you want to look into replacing the fuel pump with a walbro gss340
