Fuel supply
Old Nov 24, 2002 | 04:14 PM
Tom's Avatar
Tom
Default Fuel supply
I'd like someone to recommend a fuel pump for up to 600 hp. Will I need a pressure regulator in the system or not?
Any one know the fuel delivey capacity of the stock fuel rails? Should I uprate them? Suggestions?
Old Nov 24, 2002 | 08:58 PM
smokinHawk's Avatar
Default Re: Fuel supply
a dual intank walbro 340 would do nicly
you could use a single walbro and increase the voltage, but a dual would be better imo.
id get a arftermarket regulator too. like a charged air boost and vacuum reference.
Old Nov 25, 2002 | 04:28 PM
MIGHTYMOUSE's Avatar
i got your answer
somethin a little like this (bragging)
my fuel sys. install feel free to ask any ?'s
http://community.webshots.com/album/29211724vvFXlMScRb
Old Nov 26, 2002 | 07:43 AM
AzzHauler's Avatar
From: Richmond, VA Where fast cars, well......are hard to come by.
I've seen it in person! <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> Looks killer too, not to mention flows a shitload of fuel.
Old Nov 26, 2002 | 03:38 PM
Tom's Avatar
Tom
Holy Moly!!
Good job and a great set of pictures MM.
How do I work out the required pump pressure for my set up? (42lb injectors running a clean 500rwhp through twin turbos.)
Does the pump just keep pumping and the regulator restricts flow, or does the regulator just smooth things out?
Oh, and are the stock fuel rails up to the job.
Cheers guys.
Old Nov 26, 2002 | 05:41 PM
I dont think the stock lines or the rails or even your 42# injectors are what it will take to comfortably run 600rwhp, after all, that is what i upgraded from.
the pressure you need just depends mostly on what you want to run, since you can adjust the same sort of thing with injector flowrate in the comptuer.. mine is at 60psi at 0 vaccum.
the regulator sets the fuel pressure, without it you would only have fuel pressure based on the friction in the lines, pretty much nothing which is unacceptable.
Old Nov 28, 2002 | 02:11 PM
nbm00ws6's Avatar
Here's my Fuel System
Old Nov 30, 2002 | 11:59 AM
scottywheels's Avatar
I have the Aeromotive eliminator pump and the speed inc aluminium tank with -8 to the modified fuel rail, then -6 from the rail to the regulator then -6 all the way back for the return.
Old Dec 1, 2002 | 11:03 AM
2001CamaroGuy's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by scott ws6:
<strong>I have the Aeromotive eliminator pump and the speed inc aluminium tank with -8 to the modified fuel rail, then -6 from the rail to the regulator then -6 all the way back for the return.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Are the Aeromotive pumps loud? I think my factory fuel pump is about to go out and I was going to convert to the Aeromotive pump but I dont want something that you can hear.
Chris
Old Dec 1, 2002 | 09:53 PM
I dont think Id call it to loud. It sounds bad ***. see if you can here it on my video.
www.scottytoohottie.com
its the last link
Old Dec 2, 2002 | 12:59 AM
my twin in tank walbro's are not louder than stock to me
