ATI 3 Piece Cog System $550.95
Old Nov 30, 2002 | 05:03 PM
frcefed98's Avatar
Default ATI 3 Piece Cog System $550.95
I dont know if anyone knows about this cog set up. It sounds like a good deal with what you get for 550.95
Crank Pulley, Compressor pulley, Idler and 30mm Cog Belt.
Boost levels 10-13-15psi
www.rpmoutlet.com/fbodyaspcog.htm
J
Old Nov 30, 2002 | 05:09 PM
White SS's Avatar
Default Re: ATI 3 Piece Cog System $550.95
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by frcefed98:
<strong>I dont know if anyone knows about this cog set up. It sounds like a good deal with what you get for 550.95
J</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Ate those boost levals rated for P-1 or D-1?
Old Nov 30, 2002 | 05:20 PM
frcefed98's Avatar
The page doesn't say, just
98-02Camaro/Firebird ATI Procharger Cog Belt System
Probably for the D1-SC. It can be bolted up to either headunit though with similar results I'm pretty sure.
I found this while looking for another belt for my 3.2 pulley, the damn belt is slipping and I have little room left on the tensioner to tighten it up even more. This belt slip issue sucks. 7psi pulley was making 7psi, 9psi pulley is making 7psi and slipping.
Time to find a smaller belt, its about all I can afford right now <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
J
Old Nov 30, 2002 | 05:38 PM
XLR8NSS's Avatar
Adkoonerstrator
Mike Morgans 7.875" 6 rib crank pulley is another alternative.
If your using a 3.2" pulley now you could use a 3.6" pulley with the bigger crank pulley.
The cog setup = no slip though <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
The cog setup = voided warranty on the blower though. <img border="0" title="" alt="[Sad]" src="gr_sad.gif" /> AFAIK
John
Old Nov 30, 2002 | 06:11 PM
White SS's Avatar
Anything on my car.
Warrenty= voided long ago <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old Nov 30, 2002 | 06:42 PM
frcefed98's Avatar
Just throwing out what I found. More options are always nice, especially if you plan on doing any engine work.
MMS has a pretty good deal, but price is steep at 230 for one pulley, does he even throw in the right belt, plus you have to get the right blower pulley to compensate for the bigger CP. This equals more $$.
For 550 you get 3 pulleys a belt and no slip.
Warranty? Whats a warranty <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
ATI can't tell if I had a cog on it or not. They don't look at my car at nightime or when I'm not looking. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
I have two pulleys right now the 3.4 and the 3.2. If I ran these with a bigger CP I would overboost my stock motor. So for now I have to stick with finding a smaller belt prolly a 36.5in to help with my lil belt slip problem.
J
Old Dec 1, 2002 | 01:02 PM
frcefed98's Avatar
Lost&Found2 No problem <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
I was pretty stoked when I found that set up too. Too bad I don't have the cash for it now. oh well, maybe my family can find it in their hearts to get it for me for christmas.
J <img border="0" title="" alt="[Cool]" src="gr_images/icons/cool.gif" />
Old Dec 2, 2002 | 12:01 AM
Lost & Found2's Avatar
Thanks frcefed98, you just found what I've been looking for. <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Old Jan 3, 2003 | 08:45 PM
Has anyone tried this little setup yet? I'm going to, but i have to get a few other things first, like a rear-end, transmission, and upgrade my fuel system. <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" />
99 Trans Am Vert
D&M Blockshop 383CID, MMS StageIII Heads/Blower Cam, GWP StageII Procharger D-1. G2 Suspension & BMR Trak pak. ProYankExtreme Stall.
Old Jan 3, 2003 | 11:17 PM
MelloYellow's Avatar
I hear the power steering cog is the most expensive piece. At least for the C5. Dunno how close the F-Body setup is. Thank god I don't have to foot the bill. Vortech includes a C5 cog setup.
Old Jan 10, 2003 | 10:20 AM
02BlackWS6's Avatar
Dont they make a cog system for 7# kits? Not many people can run 10#'s or more without seriously lowering there compression. They need to make cogs for the 7# kit cause even that kit has belt slipping problems to.
