Ideas as to what happened?
Old Oct 19, 2005 | 10:54 AM
BLWNZ's Avatar
Default Ideas as to what happened?
These pistons are out of a buddys VR6 turbo. the car has Ross pistons and cunningham rods. This is the second piston that the edge is burnt and pitted . He runs 28lb of boost and 18 degrees of timing and the car is 9.1 comp. This happened a year ago at less boost but the same cylinder. Also the plugs in these cylinders look great with no signs of detonation.
Old Oct 19, 2005 | 11:16 AM
Zombie's Avatar
the ross pistons in my 89 supra looked the same after running it hard. We suspect that I was detonating it lightly for a long period of time and it just got hot.
Old Oct 19, 2005 | 11:30 AM
BLWNZ's Avatar
Did the plugs look ok becouse these were perfect maybe a little rich if anything.
Old Oct 19, 2005 | 01:09 PM
hellbents10's Avatar
LS1Tech Sponsor
To rich fuel igniting around the ring lands.
Old Oct 19, 2005 | 01:16 PM
V6 Bird's Avatar
I was going to say something similar but the the extent of too tight of ring gap on the top and 2nd rings.
Mike
Old Oct 19, 2005 | 07:47 PM
SleeperSupra's Avatar
I would invest in a wideband.
Old Oct 19, 2005 | 08:04 PM
LASTLS1's Avatar
6 Second Club Moderator
Too lean! Cylinder temps too high.
Old Oct 19, 2005 | 08:22 PM
BLWNZ's Avatar
car has a wideband. the car has never been anything leaner than 12.0. Why would the plugs not look bad?
Old Oct 19, 2005 | 09:17 PM
It ran lean. You can see the damage from it detonating around the top edge of the piston and the damage from the heat around the ring land. An air/fuel ratio of 12.0 is kind of pushing it. I like to stay safe around 11.6-11.8 to 1. Timing makes power not running on the ragged edge of being lean.
Old Oct 19, 2005 | 09:28 PM
Kind of like this...
Ran it lean and the plugs looked perfect.
Old Oct 20, 2005 | 07:42 AM
V6 Bird's Avatar
Have you cleaned that piston at all or is that how it came out of the motor?
If you havent cleaned it, then it was running lean. Ive never ran a turbo car anywhere close to 12:1 much less a nitrous car. With that kind of boost psi you generate alot of cylinder heat from cylinder pressure. Extra fueling to the tune, woudl actually make more power too. Keeping the egt's down and allowing for a cooler charge to ignite and make power with.
Mike
Old Oct 20, 2005 | 07:43 AM
MIGHTYMOUSE's Avatar
it doesn't have to be either too lean or too rich
28psi on 9:1 sounds like he was out of octane
Old Oct 20, 2005 | 07:03 PM
BLWNZ's Avatar
Thanks for the help i will tell him so it does not happen again.
Old Oct 20, 2005 | 10:14 PM
V6 Bird's Avatar
Lean=Mean=Clean Pistons too. I agree on the out of octane as well.
