Million dollar question: manifolds -vs- headers
Old Oct 20, 2005 | 05:22 PM
SPANKY LS1's Avatar
Default Million dollar question: manifolds -vs- headers
With all of the success of the truck manifold based setups (both single and twin), why would anyone go through all of the trouble/expense of having stainless headers made, I mean, at what point are they beneficial? Three of the fastest FI cars around (Ohio Boys Formula, Mike B's CE T/A, and the Stenod white T/A) all have truck manifold based systems. With these cars running as good as they are, why/when would it be "worth it" to go with a custom stainless header setup?
Mike B's car just ran a 8.96 @ 154 at 3800 lbs, how fast would he go if he had some $$$$$ headers, all else being equal?
Stenods white T/A recently went 8.848 @ 154.37, how fast would he go if he had some $$$$$ headers, all else being equal?
Just thinking out loud here.....
Shawn
Old Oct 20, 2005 | 05:36 PM
NumberOneSled's Avatar
Are you sure all those cars are running truck manifolds? If that's true, you make a good point.
Old Oct 20, 2005 | 05:43 PM
MOLESTER's Avatar
i was wondering the same thing and yes the stenod trans am does have truck manifolds. unless they just recently changed them but those are the numbers they pulled.
Old Oct 20, 2005 | 05:58 PM
y2khawk's Avatar
Probably none, we're out of turbo as it is
It might make getting up on boost on the brake faster, mine use to come up alot faster than Kevin's. I had headers and BB turbos though, so it might have been the turbos impacting spool.
Old Oct 20, 2005 | 06:04 PM
Torquemonster TT's Avatar
it's not always about more power, but making best use of what you have
20% gains are not uncommon between a manifold and equal length headers with a true merge collector into a turbo... but if you can't really use the extra power OR there is no room - logs get the job done for a whole lot less hassle
I'd do headers only because I can't stand to compromise - but that philisophy is a pain in the *** because it costs in time and money... reality is a good manifold will make huge power if everything else is right.
NA$TY-TA's Avatar
I had the choice when Stenod started on my kit.........
I think part of me wanted to do it for the bling factor..
Old Oct 20, 2005 | 06:29 PM
Drake's Avatar
Headers are nice, and no one can really argue that they aren't generally prefered, however for the trouble I'm going to have to go through to:
1.) Buy all of the bends in 321
2.) Buy the expensive 321 collectors
3.) Arrange them and weld them
4.) Inspect them and watch for cracks
It just wasn't worth it after I weighed the cost and trouble.
Yes, yes, I'm still researching a way to make up the bling factor.
Old Oct 21, 2005 | 05:42 AM
smokinHawk's Avatar
to me bling is going 150+ in the quarter.
i hope to have that bling factor one day
im sure youd pick up some, but enough to ill-warrent the durabilty of a cast manfold, to me isnt worth it
Old Oct 21, 2005 | 07:58 AM
V6 Bird's Avatar
What size turbo is he using that he is maxed out on? He's the Formula with the Twins though right?
Old Oct 21, 2005 | 09:05 AM
smokinHawk's Avatar
think he's using custom twin GT40 - 59mm from precision
yup, 1badws6's white formula
Old Oct 21, 2005 | 09:28 AM
Hawkcmc's Avatar
You cant keep your A/C with them and for some that is important.
CMC
Old Oct 21, 2005 | 09:45 AM
CHRISPY's Avatar
I wish someone would develop a nice cast manifold for our cars
Cheers,
Chris
Old Oct 21, 2005 | 09:50 AM
RyanJ's Avatar
SSU Moderator
Jose is supposedly working on dup'ing the Incon cast manifolds but modding them for a T4 flange possibly.
Even a nice forward-facing log-style manifold (like in the TTi->QTP->GZ kit) in cast iron would be cool for street cars if you could design the kit w/o the boost/wastegate issues of the TTi/QTP.
Anywho, it takes many 10's of thousands of dollars to go from mold to production in a cast manifold so I wouldnt expect toooo much.
Old Oct 21, 2005 | 11:47 AM
y2khawk's Avatar
Nothing custom about them, off the shelf turbo.
Old Oct 21, 2005 | 12:11 PM
Quickin's Avatar
CMC
Hi-Flow kit retains A/C and uses tubular 321 headers.
Old Oct 21, 2005 | 12:59 PM
I could be wrong, but I think Hawkcmc was talking about a twin turbo kit.
Old Oct 21, 2005 | 01:26 PM
Quickin's Avatar
Ooops, I'm an idiot
Old Oct 21, 2005 | 03:09 PM
Got Me SOM's Avatar
a negative to stainless steel is it will raise underhood temps by a lot. Then you'll have to use header wrap to keep the temps down.
for hp per cost factor it probably isn't worth it. If you want to be the top dog then by all means you need em.
Old Oct 21, 2005 | 03:28 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Cast OEM manifolds vs. aftermarket headers:
#1 Cost
#2 Reliability (cracking)
#3 Value-added
I guess you have to see where you end up with this list.
Spanks, this thread is definitely very though provoking, but howzabout adding the Speed Inc shop car to the list... it has custom headers.
Old Oct 22, 2005 | 10:41 AM
SPANKY LS1's Avatar
PSJ- Are you looking into a manifold setup or a header type setup?
