Anyone run a filter off the valve cover...
I know the 5.0L guys do it that way with no side effects... how about the LS1's?
I can smell the oil burning from blow-by when the crank case gets boosted.
sounds like you may have bigger problems brewing though <img border="0" title="" alt="[Frown]" src="images/icons/frown.gif" />
<strong>
sounds like you may have bigger problems brewing though <img border="0" title="" alt="[Frown]" src="images/icons/frown.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Like I said, the check valve took a dump. You can blow thru it with your mouth, so the crank case is being pressurized.
I'm sure I have the vaccuum lines right but to be safe I'll just re-check them sometime. Does anyone else have other solutions to this problem?
