Custom H-11 Head Studs Available
These will be ready next Friday the 10th and cost $375 shipped, these are custom made Head Studs in kit form made out of H-11 material rated at 265,000 psi T/S, for reference stock is 107,000 psi T/S(weak!) and the ARP head studs are about 190,000 psi T/S, H-11 is far superior to the ARP 8740 Chrome Moly, in every aspect. These will work very well on boosted apps to prevent head lifting. The company that is making these also makes all of Katech's C5R head studs that run $1,000 a set and many many top racing teams fastener's. They use this material for most Top Fuel apps and extreme power setup's, they work with this material alot, have tested it extensively and have a special heat treat procedure for it. These will come black oxide coated for corrosion resistance, These are the best bang for the buck, I will have about 16 sets availalbe, e-mail me at indacalinc@attbi.com if you want a set or more info, Thanks Dave
With head bolts you can, but not with head studs, to remove/install the heads with studs, you will have to remove the studs from the heads befoe removing/installing, as there isn't enough clearance betweem heads and cowl to lift sraight up and off, but it's easy enough to just unscrew the studs from the block , and pull them out before removing.
