42lb injectors big enough?
Old Jan 5, 2003 | 02:56 PM
chasgiv3's Avatar
Default Re: 42lb injectors big enough?
Harlan is running low impedance injectors with a converter box. I believe they are mid 80's.
Not sure which brand.
Old Jan 5, 2003 | 03:10 PM
parish8's Avatar
single digit dreamer
prety sure harlen has 96's, i see no reason why anyone would want to risk an injector that is too small when you can get the next size up easily. why not figure 80% duty cycle and .6BSFC like the experts tell you to and be on the safe side.
would 42's be big enuff, probably, if you push them. why risk it?
and using those numbers 650fwhp, .6BSFC, 80% dutycycle, 55psi fuel presure looks like you should go strait to the 55lb units
Old Jan 5, 2003 | 03:14 PM
Black LS1 T/A's Avatar
Moderator
Are 42# injectors enough to safely and reliably handle 600+ RWHP?
My opinion is no.
Old Jan 5, 2003 | 08:30 PM
rodent's Avatar
I really appreciate all the comments!
Those 50's still look good to me.
BTW- I'll be tuning with LS1-Edit on a Mustang dyno so hopefully I'll be able to get them dialed in. The guy helping me is one of the top tuners here in Denver. My main concern is I don't want to have to buy injectors twice. Seams like 42's are on the border line.
Tons of good info here!
<img border="0" alt="[worship]" title="" src="graemlins/gr_hail.gif" /> LS1tech.com members
Old Jan 6, 2003 | 12:14 AM
qqwqeqwrqwqtq's Avatar
The fuel pressure regulator is boost referenced. It adds 1psi fuel pressure for every 1psi in manifold pressure. Not really adding fuel, just equaling out the pressure differential under vacuum/boost.
Has anyone brought a high impedence 50# injector over the 700rw mark?
Old Jan 6, 2003 | 07:48 PM
Jackyl_30's Avatar
I have Ford 42# injectors, high flow fuel rails, #10 feed line, #6 return line, 2 Air Tech 225L external pumps in parallel, and a high flow fuel fuel filter. I am stilling running rich at almost WOT. O2 sensors read: B1S1= 0.95 and B2S1= 0.97
Old Jan 12, 2003 | 03:27 PM
Moderator
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Jackyl_30:
<strong> I have Ford 42# injectors, high flow fuel rails, #10 feed line, #6 return line, 2 Air Tech 225L external pumps in parallel, and a high flow fuel fuel filter. I am stilling running rich at almost WOT. O2 sensors read: B1S1= 0.95 and B2S1= 0.97 </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">What are your Injector Pulse Widths?
Old Jan 13, 2003 | 11:29 PM
Jackyl_30's Avatar
BPW bank 1= 17.99 BPW bank 2= 18.08
Old Jan 14, 2003 | 06:05 AM
AlienDroid's Avatar
No one seems to have anything good to say about the 50 lb/hr injectors.
Old Jan 14, 2003 | 11:55 AM
Moderator
<strong> I have Ford 42# injectors, high flow fuel rails, #10 feed line, #6 return line, 2 Air Tech 225L external pumps in parallel, and a high flow fuel fuel filter. I am stilling running rich at almost WOT. O2 sensors read: B1S1= 0.95 and B2S1= 0.97 </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">What do you attribute your success to, in your fuel combination? What would you say is the single most important mod in it that helps you with the flow from the 42's? How many PSI of fuel pressure are you running?
With stock fuel pressure, I can't get enough fuel to lean it out anymore above 6200 RPMs (using hte RPM/PE table).
Thanks.
Old Jan 14, 2003 | 05:22 PM
Moderator
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by rodent:
<strong> I think the answer for Jackyl running rich is he's at 6,100 feet in Colorado Springs. I'll be running mine at 5800 feet. At sea level, he might have lean fuel issues. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">That's right! I forgot that he was around there. He doesn't need as much fuel because he doesn't get as much air!
Old Jan 14, 2003 | 07:43 PM
  #32
MelloYellow's Avatar
My calcs show you'll need more than a single 255lph pump to support 50# injectors FWIW.
Old Jan 15, 2003 | 12:22 AM
  #33
rodent's Avatar
Old Jan 15, 2003 | 04:40 AM
  #34
Moderator
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by MelloYellow:
<strong> My calcs show you'll need more than a single 255lph pump to support 50# injectors FWIW. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Didn't he say he had two in parallel?
Old Jan 15, 2003 | 08:58 AM
  #35
I wasn't talking to him directly.
Just noting that most of us with singles can't max out the 42's. So make sure you have the pump before you worry you need bigger than 42's.
Old Jan 15, 2003 | 10:38 PM
  #36
Jackyl_30's Avatar
I guess the altitude keeps me running rich right now. I just have a minimum tune for now. I will get it tuned in completely once I get a new tranny. It does not want to go into third very esily at WOT. Anyway, I would hope that if I kept the tune like it is now and then go to sea level that it would even out. Who knows. Any way, here is a pic of the pump set up. It is hard to tell from it, but that feed line is as big as a garden hose.
<img src="http://dodgetrucks.org/photopost/data/239Dsc00758.jpg" alt=" - " />
Old Jan 15, 2003 | 10:42 PM
  #37
BIGBOS's Avatar
What kind of twin inlines are those?
Are you running an intank pump as well??
Old Jan 15, 2003 | 11:26 PM
  #38
Jackyl_30's Avatar
I believe he called them Air Techs 225L. I have no in-tank pump. Here is another pic of the fuel system.
<img src="http://dodgetrucks.org/photopost/data/239Dsc00756.jpg" alt=" - " />
Old Jan 18, 2003 | 06:15 AM
  #39
Moderator
That looks REAL shweat! <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
