Replace pusher or add puller fan for ATI setup?
Old Oct 24, 2005 | 09:27 AM
ChevyChad's Avatar
8 sec potential, 12 sec slip
Default Replace pusher or add puller fan for ATI setup?
My car is running hot since the S/C install (like 230 just driving around in stop and go city traffic) Should I replace my existing 16” puller fan that was supplied with the procharger kit with a higher flowing one, or add a 16” pusher fan in front of the radiator and condenser? What does the ATI supplied fan flow anyways CFM wise? What has worked for everyone else out there?
Old Oct 27, 2005 | 06:45 AM
EPP's Avatar
EPP
First of all, make sure the fan is blowing the right direction. We don't normally have heating problems with the ATI ProCharger fans, although I realize I'm in the Midwest, but still you shouldn't be seeing any problems at this time of year. It is very easy to get the wiring for the fan backwards, check that out first. Bob
