Is 500rwhp streetable?
Old Jan 12, 2003 | 09:20 PM
StupidFast's Avatar
Default Is 500rwhp streetable?
I am in the process of blowing a decent amount of money. I am building a blown 5.7 to install in my 2002 truck. I am shooting for a least 500rwhp with my combo. I will have: 5.7 mildly ported heads, eagle rods, forged pistons, stock crank, 9.2? compression, 2002 LS6 cam, LS1 edit, heads and main studs, 42 or 50 lbs injectors, and an ATI running between 8 and 12 psi. I hope these items will do it. I am wondering will I be able to drive this everyday? Meaning will it last 50,000 miles, be comfortable to drive 450 miles to south Texas, and get more than 10 miles a gallon.
P.S. If you see any problems with my items please tell me.
Old Jan 12, 2003 | 09:29 PM
BIGBOS's Avatar
Default Re: Is 500rwhp streetable?
That should be a good setup, get descent gas mileage, I don't know about if your running around on a lot of boost all the time though, but it will be a very quick truck... <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
I plan to have more than 550rwhp in my car, and I drive my car every day its nice out.. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> Except when it rains/snows, etc.. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Jan 13, 2003 | 05:47 AM
smokinHawk's Avatar
500rwhp streetable/practical, not realy..
anything over 300rwhp on the street is not needed.
But most of us here are unpractical.
on my set up i have the alum block with 6.0 truck heads forged rods / pistons set at 9.0:1 CR.
Still get 20mpg, unless i get on it. 512rwhp can break street tires loose at 100mph <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> so watch out.
I drive my TA over 400 miles a week. With FI it makes cars streetable.
Id go with the 6.0 truck heads instead of the 5.7s.
42lb SVO injectors should be enough for 500rwhp (its what i got).
Old Jan 13, 2003 | 10:16 AM
tbyrne's Avatar
500hp can be very streetable, it just depends on how the car is set up. To me a car starts to become less streetable when you have to climb over a roll cage and put together a 5 point harness all the time. An exhaust/blower that is to loud starts to take away from it's street manners too. Motorwise something with 500hp can be driven like a "normal car" unless the cam is to radial and you have to deal with the car surging at low RPMs. Your combo should be fine <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Tom
Old Jan 13, 2003 | 09:00 PM
StupidFast's Avatar
Thank you for your reponses. I am still using the search portion of this site for information.
Old Jan 13, 2003 | 09:33 PM
jimmyblue's Avatar
Moderator
Anything that (theoretically) produces over
1g of acceleration is wasted, pretty much.
Hard to get 100% weight transfer and a static
friction coefficient much over 1 (Velcro(tm)
aside).
3500lb*(tire radius(ft))/(rear end ratio)/(trans gear ratio) = engine usable torque limit*
* A/T may divide by STR depending on RPM
3500*1.1/3.23/3.06/1.8 = 216lb-ft to exceed
(1st gear, A/T, stock converter, torque mult)
- roast 'em from stop
3500*1.1/3.23/3.06 = 389lb-ft to exceed
(1st gear, A/T, stock converter) - roast 'em
from top of 1st
3500*1.1/3.23/1.63/1.8 = 406lb-ft to exceed
(2nd gear, AT, torque mult) - chirp second
3500*1.1/3.23/1.63 = 731lb-ft to exceed
(2nd gear, AT) - break loose at top of second
Go by torque, not HP. 500 lb-ft will make
first gear smoke but if you drive well,
will not lose adhesion in second. Unless
you jerk it loose. Above are based on a
static friction scenario, once you lose
grip you are into sliding friction and
coefficient drops to .2 - .5X (rough rule).
This is streetability in terms of putting
down what you're putting out.
Streetable in terms of idle, overheating,
and such, you're on your own.
