what A/R should i get
Old Jan 14, 2003 | 02:26 AM
OOsilverado's Avatar
Default what A/R should i get
at first i was planning on using a T3/T4 turbo with a .6 compressor and .48 turbine. but after researching i think i should maybe step the turbine side up to a .6 as well. what do you guys think?
Old Jan 14, 2003 | 11:37 PM
y2khawk's Avatar
Default Re: what A/R should i get
YIKES!! .48 <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" />
They'll spool faser than you know what to do with, but choke off the motor before you make any decent power.
.6 atleast. Mine are .86 on a T25'ish hot side. And i have a feeling they are beginning to limit me. But then again, i'm insane <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
.6 will be a better choice IMO
Old Jan 15, 2003 | 01:20 AM
this is a twin turbo setup
would you still say get .6?
i wasnt sure if you knew that at first
Old Jan 15, 2003 | 01:43 PM
Phate's Avatar
Ryan,
FYI...Harlan's car is a twin turbo as well, so I think that is where his advice was coming from <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Scott
Old Jan 16, 2003 | 02:38 PM
TchargedLS1TA's Avatar
NEVER question the almighty single digit LS1 owners....
Old Jan 16, 2003 | 09:12 PM
i wasnt questioning i just didnt know if he knew.
i think i may go for the .83 a/r now, but its still a toss up between that and the .6 now
Old Jan 17, 2003 | 01:06 AM
MelloYellow's Avatar
What does A/R stand for? Something Ratio?
Old Jan 17, 2003 | 01:46 AM
A/R is the ratio of the Area over the Radius of the compressor or turbiune housing.
Old Jan 17, 2003 | 02:16 AM
y2khawk's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by TchargedLS1TA:
<strong> NEVER question the almighty single digit LS1 owners.... </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">And what exactly is that all about??
Yes, A/R is the ratio of the cross sectional area of the housing scroll vs the radius out on the turbine or compressor wheel.
In the simplest terms, it impacts the speed of the turbine. The smaller the A/R the less exhaust flow it takes to make a certain turbine and thus compressor speed. Small A/R spool fast, but are limited in their flow capacity.
And yes, I was aware you're putting together a twin setup.
Old Jan 17, 2003 | 03:59 PM
i think im gonna go with a .82 now. thanks for the help
