detonation and preignition?
If you have an engine that is 'dieseling' you won't be able to fix it with timing.
Common causes of pre-ignition are hot spots in the combustion chamber.
Different design plugs, lower compressions, cleaner combustion chambers, and better gas are all ways to help with pre-ignition.
A good example of this is a nitrous car with too big of a shot and the wrong plug. You may pull timing, but as long as your plug electrode is providing enough heat to ignite the mixture as soon as it gets into the cylinder chamber, pulling timing wont do anything.
or to be more precise , put better headers to lower the restriction , thus lowering boost. will that help with preignition?
another question , are the tr6 plugs as cold as the NGK BR7ef plugs?
you need to drop your compression, go to a colder plug, or run more octane..(or run some top end cleaner through the engine)
If you are going to be pulling the heads off though, I would just recommend getting some port work done to your combustion chambers rather than decking them.
I wouldn't increase the header gasket thickness. I think this is one of the poorer ways to decrease compression because of the above mentioned reason.
Another suggestion would be to run a recessed sparkplug. A shorter plug, which runs with a recessed electrode will kill two birds with one stone: It will get the plug out of the heat, and decrease your combustion chamber size slightly.
Good Luck,
Kevin
Pre-ignition creates a knock (blip on the KR sensor voltage) at a point prior to igntion.
Detonation creates a knock at a point after ignition.
Perhaps there is a scantool out there that can do it, but I don't know of one. Tech2?
Other than that, I really can't think of a rock-solid test to give a 100% difference between the two.
Good Luck,
Kevin
