LS1 Motorsports Single Turbo Update: DYNO GRAPHS!
Re: LS1 Motorsports Single Turbo Update: DYNO GRAPHS!
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by MIGHTYMOUSE:
<strong> Straight From the fires of Mount DOOM!
</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Haahaha. I like it!!!!
Yes that is some insane torque!
Rob,
Is that your base kit numbers there with 50# injectors and base LS1 edit tuning that comes with the kit?
Can you outline everything for me? If the car has heads/cam setup, what compression it is running etc etc...
That torque and HP is crazy considering where you are letting off hehehe!!
Do you have a provision for a cat in your setup?
With my heads (.298 cfm) an emissions legal 222/222 114LSA cam and your turbo with 7#'s on pump gas sounds nice <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Thanks!
Chris
Thanks!
Chris
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Chris ARE 360:
<strong> Rob,
Thanks!
Chris </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Chris:
It's a bone stocker with the exception of a Borla. The injectors are 37s which have proven to be more than the car needs. The best route is to get your own tune on a Mustang Dyno. It now has 17,000 miles of really abusive driving and it is still holding on to the stock 10-bolt and stock trans, yes with passes on ET Streets to boot. Turbos are comparatively (S/C) easy on the engine and drivetrain, even with that torque.
With good heads you'll be seeing less boost with the same power level than this car, and while your cam is a better choice than the 112 hammercam. Wider LSA and less duration (for less overlap) is the ideal situation.
Snap one up!
SC-
<strong> Rob,
Thanks!
Snap one up!
SC-
its also awesome to see the power range is from 3500 to 5000 rpm's.. no need to spin this to the moon to make power like s/cs and h/c cars.. nice and useable power for the street and strip.
thats probably why the graph doesnt go to 6.. it doesnt need to.
chris, the kit is off road only, but you could put a cat in there if you really wanted to... still wouldnt be legal clean and clear though..
i have a 3" single in and out random tech cat brand new if you are interested.
Personally I wouldn't buy the kit if I didn't see it make HP to AT LEAST 6K. Honestly 6k is nothing.
A narrow RPM width is not what I'd want as an LS1 owner. Even with a turbo.
I say fix the problems and let's see a full dyno run.
Moderator
AWESOME! <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Your 37#'ers may not be enough when you get over RPM's or more. I predict the horsepower will peak out WAY better as RPM's rise. What elevation are you at?
There's a lot in that monster, yet!
Way to go!
Way to go!
!Dial-up Director
You don't need big CI's when you have boost. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
I think a forged 9:1 346ci with a mild, stock sounding cam, a monster fuel system, and a turbo is the way to go. I have been wanting to do this for awhile and these results are making it hard to keep the credit card in my wallet.
I am still interested in how hard it is to tune with the stock computer...
Justin
Justin
#32
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by bo0oost:
<strong> How reliable has the 6 speed been at almost 700rwtq? </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">No issues. He uses the Spec and I think it's the carbon disk, but it may be the ceramic.
SC-
SC-
#33
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by chasgiv3:
<strong> Personally I wouldn't buy the kit if I didn't see it make HP to AT LEAST 6K. Honestly 6k is nothing.
I say fix the problems and let's see a full dyno run. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">LOL!!
Yeah, I guess 600+ lbft of tq for ~1700rpm is way too narrow of a power band! <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> (Not a flame) Honestly, your power band only has to be slightly wider than the rpm drops between gears (on a 6 speed)...an auto can make up for this with STR, incomplete lock-up, etc.
Nice numbers Rob.
As for cam choice, what would you suggest for ideal lift numbers? (If you don't mind sharing). Looks like a pretty nice platform to build off of...might be in my future <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Nice numbers Rob.
#35
I can shift faster than you.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Jsears8:
<strong> I think a forged 9:1 346ci with a mild, stock sounding cam, a monster fuel system, and a turbo is the way to go. I have been wanting to do this for awhile and these results are making it hard to keep the credit card in my wallet.
</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif"><img border="0" alt="[evil]" title="" src="graemlins/gr_devil.gif" /> , I think we need to get started on this Justin. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
#36
So once he upgrades to better valve springs the graph won't drop off? When comparing the 2 graphs it still looks like it drops off even before the valves float? Maybe the T-76 would cure that <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
