LS1 knock sensor vs LQ4 knock sensor
Old Oct 25, 2005 | 08:18 PM
01Bird_of_Prey's Avatar
Default LS1 knock sensor vs LQ4 knock sensor
I had a 408 built with the best stuff I could afford - 15psi and was making over 800rwhp, but I kept having problems with lifting heads. I bought AFR 225 heads - it helped till the # 6 &7 piston ringlands let go and the builder said it was detination, but I never saw any knock, well it did knock some times during shifts and low acceleration, but no more than two. I checked the dealership and they're a different part # for cast iron vs. aluminum.
I'm thinking that the knock sensor in an aluminum block might be less sensitive than ine in an cast iron - if I'm wrong, or this is or isn't an issue let me know.
The pistons rattle themselves to death with no damage done to the top of the piston or spark plugs.
Thanks
Old Oct 26, 2005 | 04:49 PM
No one has any idea?
