does a gt47(88mm) really spool faster than a pt88?
Old 10-24-2005, 04:38 PM
single digit dreamer
parish8's Avatar
Default does a gt47(88mm) really spool faster than a pt88?
i have been hearing for awhile that the gt47 has some "new technology" that allows it to spool faster then older turbo styles. even thought the gt47 is rated at more hp than the pt88 will it really spool faster?
Old 10-24-2005, 05:19 PM
smokinHawk's Avatar
thought they both used the same wheels, just different housings
Old 10-24-2005, 05:25 PM
NA$TY-TA's Avatar
thinking about switching again huh.......
Old 10-24-2005, 05:48 PM
parish8's Avatar
no, if i switch it will be up to twin 70's or something like that. just something i have heard a few times and something a local buddy is telling me. i was wondering if there was any truth to it.
Old 10-24-2005, 07:47 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,141 Likes on 741 Posts
Jim, you made 1011rwhp just turbo, no spray?
Old 10-24-2005, 07:59 PM
parish8's Avatar
yep, on pump gas with meth
Old 10-24-2005, 08:47 PM
NA$TY-TA's Avatar
so when ya gunna do a few pulls on C16 with spray????? ha ha ha
Kyle
Old 10-24-2005, 08:57 PM
parish8's Avatar
Kyle
in a few weeks , busting out a 9 sec run is way higher on my list of things to do and i am running out of time.
this is what happend last saturday when i turned it up. i kept the nitrous on, this was the first time i tried running any nitrous other than a spooling shot.
Old 10-24-2005, 09:02 PM
69firebird's Avatar
man you got all of that drivetrain messed up
Old 10-24-2005, 10:09 PM
Brains's Avatar
Hmm, time for a billet yoke my friend.
Old 10-24-2005, 10:11 PM
LS1TECH Sponsor
JZ 97 SS 1500's Avatar
Parish, yes the GT47-88 will outspool the PTE-88. IF you need any additional info feel free to call.
parish8's Avatar
i dont think the yolk broke first, looks to me like the u joint took it out.
i have a 1350 yolk on the way and then a chromolly shaft with 1350 u joints. there are still lots of stock parts under the truck to break. i am suprized it lasted this long.
Old 10-25-2005, 10:40 AM
stevewix's Avatar
i'm the guy building the car/motor parish is referring to; funny thing i was just about to post the same topic! it seems to me like i would be overkilling the hell out of this one with a damn t6-framed turbo; but i keep hearing they outspool the pt88;
won't this turbo be absolutely HUGE for a 370" motor? it seems awfully big....
Old 10-25-2005, 11:08 AM
NA$TY-TA's Avatar
I hear ya on that....... will the parts be in in time?? when does the track close up there?????
Old 10-25-2005, 01:44 PM
John Wilde's Avatar
From what I have heard your ci is about max for the GT-47 in a single application. I am sure Jose will chime in.
Old 10-25-2005, 01:48 PM
LS1Tech Co-Founder
Brian @ Precision Turbo has been advocating the GT47/88 due to it's increased efficiency over the PTE88.
From what I have gleaned, the GT47/88 will make over 1400. and the PTE88 (both with the T6 flange) should make close to that...
I'm still not clear on the distinct differences. The PTE88 uses old technology and an older design turbine wheel.
Old 10-25-2005, 01:59 PM
LS1TECH Sponsor
The GT47 uses different wheels indeed. Actually the GT47 exhaust turbine is smaller then the PT88 (ala quicker spool when both use same A/R). Problem with the GT47 is just the physical size....very big. Also the only drawback to the new more efficient GT47 turbine wheel is with the larger engines at high boost the backpressure goes up pretty quick. Its reaching more then 2:1, which is not good for a T6 big frame unit. But the new more efficient wheels do give better mid range then the older TV style wheels.
JZ
Old 10-25-2005, 02:09 PM
LS1Tech Co-Founder
JZ, what are the overall sizes of each turbo? Is the GT47 12/12/12"?
Old 10-25-2005, 02:15 PM
gnx7's Avatar
Parish- are you still running the stock 1/2 ton front and rear axles/diffs?
That truck is mean... wonder what that combo would do in my 2800lb RX-7 with .29cd (aero)?
LS1TECH Sponsor
I don't have the measurements on me here, but this is a good gauge.... The GT47 and PT88 are the middle 2 units.
JZ
Quick Reply: does a gt47(88mm) really spool faster than a pt88?
