Boost on a D1SC
Old Oct 26, 2005 | 08:06 PM
02' hawk's Avatar
Default Boost on a D1SC
About a month ago i did a cam swap and put it all back together now the boost is only going up to about 5-6 lbs. What is controling the boost? I know there has to be at least another 2 lbs in it.
Old Oct 26, 2005 | 08:27 PM
Got Me SOM's Avatar
what cam did you put in?
you'll lose a little bit of boost with the cam cause its making your motor more efficient now. Now ya just gotta pulley up to get it back where it was.
Old Oct 26, 2005 | 08:32 PM
02' hawk's Avatar
Comp Cam 54-444-11 581/588 @ 114 lsa
Old Oct 26, 2005 | 08:33 PM
02' hawk's Avatar
Who has a pulley for more boost?
Old Oct 27, 2005 | 01:43 AM
TrakDay's Avatar
I was running a 4.25" pulley with my Comp 224/228 .581/.588 114lsa cam and I was seeing about 8.5psi at 7k rpms and about 7psi at 6200rpms or so. I am changing my pulley to a 3.85" this Sunday that I bought from Bob at EPP and I am hoping to see close to 8psi at 6krpms or atleast before 6200 I hope!
Whats size is your pulley now? I know you can order pulleys direct through Procharger and they are only like $85 or so!
Old Oct 27, 2005 | 06:16 AM
EPP's Avatar
EPP
Anytime you change cams, cylinder heads, add headers, exhaust, etc, it can have an effect on the boost that will be made. Almost everytime you change from a stock camshaft to a performance grind, the boost that the blower can make will be lower.
Since you have a forged bottom end you can shoot for 12 psi or more, but you will want to get your car retuned. Bob
Old Oct 27, 2005 | 11:44 AM
02' hawk's Avatar
Thanks everyone this is all good info. It all makes sence now!
Old Oct 27, 2005 | 11:45 AM
02' hawk's Avatar
How diffacult is the head unit to remove? I know that the pulley is faceing the alternator. I think that the pulley size is whatever came from procharger.
Old Oct 27, 2005 | 02:23 PM
NA$TY-TA's Avatar
easy...... its 5 bolts.... uses allen heads..... one bigger one and 4 smaller ones...... then reset tension back on your tensioner if you dont need a smaller belt already... wich u probably will.
Old Oct 27, 2005 | 02:40 PM
02' hawk's Avatar
Where do i get another belt? Procharger?
Old Oct 27, 2005 | 03:08 PM
NA$TY-TA's Avatar
hell no not prochrager... they will sell u a Gates belt for like $40 + 12 to ship it when u can go to Napa or Auto zone and buy one for like $17
what size pulleys first of all and what length do u need.... if u order a smaller blower pulley order the pulley from ATI and ask them the belt length and get it local.... and what ever u do dont tell who ever you buy it from its for a blower....... that way if u destroy it most of the time they will replace it for free... ha ha
Old Oct 27, 2005 | 03:16 PM
WHPLASH's Avatar
Are you a 6 rib or 8 rib setup? I have a couple new 6 ribs and belts.
Old Oct 27, 2005 | 03:53 PM
02' hawk's Avatar
It's the 8 rib
02' hawk's Avatar
YEA that's alot cheaper!
