Can I drive without tune?
Old Oct 27, 2005 | 03:12 PM
LastBlack02SS's Avatar
Default Can I drive without tune?
I'm putting a ton of stuff on my car. I wanted to know how long or far I could go with it all installed before I get a tune. I'm installing stuff in southern california over thanksgiving and may not be able to get a tune until i get back up to school 400 miles away. Is this something that I can do, a 400 mile freeway drive with all of this installed without killing my car?
Powerdyne Ls1 kit
42# injectors
Walbro 255 fuel pump in sending unit
SLP 160 thermostat
TCI 3500 stall 2.5 str torque converter
Pacesetter coated LT's w/02 extensions
TSP Catted Y pipe
3.73 gears
I have a HPP3 if that would help at all for the meantime.
Old Oct 27, 2005 | 03:23 PM
Blackbird's Avatar
everything but the injectors would be ok. not sure if the hpp3 can compesate for those or not.
Ed Blown Vert's Avatar
Don't do it. The larger injectors will make you run really rich.
You could leave the stock injectors in and drive it with your foot out of boost.
Old Oct 27, 2005 | 03:30 PM
explain "with your foot out of boost", and what about the HPP3, just dont use it
Old Oct 27, 2005 | 03:32 PM
Blackbird's Avatar
as long as you dont get into boost you wont risk blowing up the motor from detonation.
hpp3 will be fine to change gear ratio for the drive.
i dont know if the hpp3 can compensate for bigger injectors, if not you need to leave those off the car until you tune, or you will wash the cylinders, ruin the cats, car will barely run, etc....
Old Oct 28, 2005 | 06:05 AM
todd4168's Avatar
no way hose!
Old Oct 28, 2005 | 05:44 PM
so don't do it? I keep getting mixed opinions.
Old Oct 28, 2005 | 08:11 PM
WestSide's Avatar
Don't do the injectors YET. have the tuning shop put them in, or you can put them in when you get there. They will make you run really rich, so leave them out for now and go easy on the throttle on the way to the tune shop. Stay out of boost.
Old Oct 29, 2005 | 02:51 AM
DeltaT's Avatar
One of the rare cases where you have to drive like a ***** to succeed
Old Oct 29, 2005 | 03:57 AM
venom346's Avatar
I wouldnt do it, I lost my last engine due to lack of tuning it immediately. as a result, im currently building a new block deteonation is a #$@$@#
Old Oct 29, 2005 | 07:46 AM
EPP's Avatar
EPP
We have people drive from other states to our shop to get a tune, without any problems. As has been mentioned, don't install the larger fuel injectors until you get to the shop that is going to do the tuning. As long as you drive part throttle, you won't have any problems. Do NOT got wide open throttle, even if it is just for a second!!!
You could use your HPP3 to change the gear ratio for the drive there. Don't install the performance tune part of it, as you don't need it running any leaner. Bob
Old Oct 29, 2005 | 09:28 AM
speedz06's Avatar
Check your AFR's,see if you are getting any knock ret.--then that will answer your question.
Old Oct 29, 2005 | 09:54 AM
HOSS's Avatar
yea, DO NOT PUT THE INJECTORS IN...car will barely run if you do..pm me when you have the blower on, i have one also that is going on in 2 weeks, waiting on my fans and pushrods for the cam
