LS1M Production Kit #1 arrived today.
Re: LS1M Production Kit #1 arrived today.
full street trim exept for rear slicks, full interior ac/stereo etc.
600 rwhp, pump gas, somewhere around 15psi on the small turbo
10 second pass and 130mph trap with the above is my goal for my daily driver <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
the install will begin soon as the weather clears and i have instructions to follow. but the tuning will go on for the better part of the spring i imagine building up the boost as i go.
i will probably have to swap the 42# injectors out for larger before its all done..
then if i get bored with that, there is always the big turbo <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> and race gas.
<small>[ February 19, 2003, 12:26 PM: Message edited by: MIGHTYMOUSE ]</small>
did you dyno the motor NA?
I am curious as to the power output of a HCI 8.75:1 comp car <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
thanks,
Chris
thanks,
Chris
yes i did
i dynoed it with longtube headers, random tech cat back, no cats, ls6 intake 85mm maf, ported tb, 30* timing, no knock through that driveshaft and 12 bolt with the 3.73 gear.. oh and a lid with no filter
did 301 rear wheel standard correction (sae?) on the same dyno that a bone stock ls1 dyno's around 300 rear wheel on. and i ran a 13.1 at 108 like that as well on a 2.0 60'
..so im basically looking to double my output.. hence the 15psi <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
in all fairness though if i spent any time at all to try to tune it to run n/a im sure i cold have pulled another 20 horse out of the computer and with a hotter spark plug than tr6 <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
<small>[ February 20, 2003, 10:09 AM: Message edited by: MIGHTYMOUSE ]</small>
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Pro Stock John:
<strong> Hey Curt, you can bust mah ballz but I went 11.02 with crank issues, NA, on pump gas and you went 10.95 with a race block and a turbo... Maybe you need to run a little faster before you can act like you can pass judgment on me sonny. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
John
11.02@122.6mph 3520 raceweight </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Does that mean I can bust your ***** Johnnny??? <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Chris
10.9 @ 123.50.......with Cubic inch issues!
Stock shortblock heads/cam 3475#
John
Chris
the 60mm is verymuch for sale, but ist kinda trashed, email me and ill send you pics of it.. i was selling it to some ricer guy and he dropped the dam thing on the turbine fins <img border="0" title="" alt="[Mad]" src="gr_images/icons/mad.gif" />
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by MIGHTYMOUSE:
<strong> the 60mm is verymuch for sale, but ist kinda trashed, email me and ill send you pics of it.. i was selling it to some ricer guy and he dropped the dam thing on the turbine fins <img border="0" title="" alt="[Mad]" src="gr_images/icons/mad.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">After he dropped it, I would of told him he just bought a turbo.
[QB
ross offset ring boost pistons 8.75:1 compression
[/QB]</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">What is the throttle response and low end tourque like?
[QB
#32
it will spin first from a roll with street tires but wont chirp second if you just stab the gas.. its pretty darn sluggish, but thats about to change. install starts tomorrow afternoon
#33
MIGHTYMOUSE, did you get my email? Let me know what you want for the turbo. If the price is right the damage won't be a big deal. Hows the install coming with the kit?
#34
I notice that cam has a good idling 115 lsa but the durations are up there. Does that thing drive well or is it one that you have to learn? Lifts are relatively low so I assume that it doesn't have a lot of valvetrain chatter, or does it?
#37
i need an exhaust bracket to hook up to the random cat-back but i SHOULD have a drive in it early tomorrow morning
i had to move the pics to another page, here it is.. some new install pics there too..
http://community.webshots.com/user/mightym0use
#39
from what i understand, eventually all of the discharge side will be silicone, not just that one red tube, it will shave some weight, simplify installation and look coooool <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
fuel system pics are on my sig page
-8 fuel pressure line, speed inc regulator, rails and filter, -6 return line, twin gss340 walbro in tank pumps green top 42# svo injectors if they hold. switch to those 55's if not.
