TTi Stage X - Stock Bottom End - Corvette Dyno Numbers
For grins I decided to run my car last night on the dyno.
Setup:
-- Stock 346 motor with approx 9.6 CR (bigger cc LS1 heads).
-- TTi Stage X
-- 10 lbs of boost
-- LPE GT2-3 cam and WCCH LS1 heads.
These are numbers on a conservative Mustang dyno. Pump gas. No meth. About 15 degrees of timing (trying to keep the stock motor alive for a while). AFR is in the 10's.
Car still has stock rods, pistons, timing chain, oil pump, etc.
Verdict: 592.8 rwhp @ 6300 RPM and 568.3 torque at 4550 RPM
Dyno Sheet:
http://www.mdhmi.com/pics/mdhmi/mdh-tt-1.jpg
Cheers,
Mark
Setup:
-- TTi Stage X
-- 10 lbs of boost
Dyno Sheet:
Cheers,
Mark
The LPE GT2-3 cam is only slightly larger than a Z06 cam. You really can't even tell it's there. The driveability is totally stock. It's a great daily driver cam IMO.
Mark
Mark
