W2w
Old Nov 18, 2005 | 11:54 AM
  #41
1fastWS6's Avatar
Kurt,
When is the "big dog" Rotrex going to be available? One big enough to feed a 500" BBC and 1500HP? Anytime soon?
Old Nov 18, 2005 | 11:12 PM
  #42
427's Avatar
427
No plans for that blower ever!! These blowers are made for dailly driven cars that want power without increased noise. We will have some cars/trucks on Power tour with blowers working that you can check out.
Kurt
Originally Posted by 1fastWS6
Kurt,
Old Nov 19, 2005 | 08:17 AM
  #43
Jammer's Avatar
Originally Posted by Kev@WheeltoWheel
Warren,
In order to fit that kit on an F-car it would require a lot of work. The blower would not clear the hood and I believe a dry sump would need to be used.
A custom F-car specific application could be made but it would be quite expensive.
What cars was the twin kit designed for? Pro touring custom stuff? I guess what id like to know..any others..what fab work is needed to add this to an F-body. Its a serious question.
Looks awesome
Old Nov 21, 2005 | 02:44 PM
  #44
Kevin@W2W's Avatar
LS1TECH Sponsor
Looks awesome
Let me look into this a little. I'll shoot you a pm.
Old Nov 21, 2005 | 02:56 PM
  #45
1fastWS6's Avatar
Kurt
I thought I read in Fastest Street Car that this was something you guys were working on due to the better efficiency of the Rotrex vs typical centrifugal blowers????
Old Nov 22, 2005 | 07:08 AM
  #46
JIMMYZZ28's Avatar
I look at this page everyday http://www.w2wpowertrain.com/t-techRotrex-2.aspx they look badass and with any luck we hope to be the ones supplying the intercoolers for these. Kurt do you know if Dan has had a chance to look at all the modeled data we sent in? We did this two ways water to air and air to air. If you note the air to air kills the performance of the water to air.
Thanks, Jim
Old Nov 22, 2005 | 07:41 AM
  #47
427's Avatar
427
Jason,
The twin kit was something I did for increased output, and some things just seem better in pairs!
The original car that will get fitted with this is our 72 Nova project car. It will still be tight for hood clearance.
It will also rock in a marine application. The engine is under 450lbs with blowers!!(900+hp)
The late model F-car hoodline is to low for the twin set-up. It will be older cars that will benifit from this.
Kurt
Old Nov 22, 2005 | 08:52 PM
  #48
longrange4u's Avatar
When are you going to come out with the I-5 setup for the Colorado? Any idea on what that will do for performance?
Old Nov 22, 2005 | 09:46 PM
  #49
427's Avatar
427
We are just starting the process now. It will be the middle of 06 before it is released. Should have dyno info in the begining of the year.
Kurt
Old Nov 22, 2005 | 09:50 PM
  #50
69firebird's Avatar
Looked through that power point, very very well put together, Id imangine you guys have made some sales off of it
these look like good kits, what is the approx price for the truck kits?
are you going to be releasing the kits for the 8.1 kit, or was it one off?
Old Nov 23, 2005 | 09:38 AM
  #51
427's Avatar
427
The truck kit retails at 4400. The 8.1 dually was a dual fuel hydrogen/gas powered one off deal, we added the boost only when running on hydrogen to replace missing hp. The brackets are billet one off parts, it is not on the schedule for a kit.
I will tell the guy(Brad Shantry) that made the power point presentation you liked it, he did a great job.
Kurt
Old Nov 25, 2005 | 09:16 PM
  #52
seadoo's Avatar
do you have a price for a single kit? if you dont wanna post it please feel free to PM me. Thanks
Old Nov 25, 2005 | 10:19 PM
  #53
Jammer's Avatar
Jason,
Kurt
Thanks Kurt... But I have a plazma cutter and will cut to fit, especially if its just the hood. Were funny like that here... see pic.... Theres a hood thats "fits" this nicely"...
Old Nov 25, 2005 | 10:33 PM
  #54
427's Avatar
427
The single truck kit is 4,400.00 dollars.
Kurt
Old Nov 25, 2005 | 10:34 PM
  #55
427's Avatar
427
Your just not right!!! We will have a dual set-up on a engine at PRI. Stop by and take a look.
Kurt
Old Nov 27, 2005 | 02:52 AM
  #56
Jammer's Avatar
Will do/
Old Dec 4, 2005 | 08:00 AM
  #57
DanaliHD's Avatar
That twin Rotex has my name all over it. BUT, how in the hell do you get the outlet piping to the intake manifold? doesn' look like it's possible. hook a brotha up.
Old Dec 5, 2005 | 10:44 AM
  #58
Kevin@W2W's Avatar
LS1TECH Sponsor
In order to run the twin kit you have two options.
A single plane carb style intake with an elbow or you can use an injected manifold spun around so the throttle body faces the firewall. The latter is the combination that will be used in our project Nova.
Old Dec 5, 2005 | 12:30 PM
  #59
marcus769's Avatar
I saw the W2W trucks on the 2005 Power Tour. I was very impressed! Loved the GTO, and the trucks were bad assed too! The work on their vehicles looked to be very professional. Keep up the good work guys! Good luck with the new products! Hopefully I can make it down to FL for the 06 Tour to see your new stuff!
