How loud is the T-trim?
Old Feb 24, 2003 | 06:47 PM
2001WS6Vert's Avatar
Default How loud is the T-trim?
I have downloaded clips from the internet but have not heard one in person. I was wondering if someone could describe how loud it is.
Old Feb 25, 2003 | 03:24 PM
CHRISPY's Avatar
Default Re: How loud is the T-trim?
How much did the bracketry cost for that system?
Can you get a cog setup?
cheers,
Chris
Old Feb 25, 2003 | 08:26 PM
CoopDog's Avatar
I bought the head unit and the conversion kit at the same time, was somewhere over $3000. T-trim alone is about $2000. I'm not sure if there is a cog system for this, I didn't consider it at the time I ordered. I lost about 15lbs. sweating just trying to get the belt on, it is the tightest I have ever done!
<small>[ February 26, 2003, 09:16 AM: Message edited by: CoopDog ]</small>
Old Feb 26, 2003 | 12:35 AM
CoopDog's Avatar
I switched from the G-trim to the T-trim, the T-Trim doesn't seem to be any louder than the G-Trim. It is hard to tell though when you don't have the 2 to compare at the same time. It is stll fairly loud though, there is no doubt tat you are running a blower under the hood. If you have the hood open, you have to talk loud/shout to talk to someone standing nearby. I don't have any soundbytes to listen to, but hopefully the description helps.
Old Feb 26, 2003 | 12:38 AM
RyanJ's Avatar
SSU Moderator
Does anyone have pics of the T with a hood on (non-ramair), especially the Camaro hoods?
Old Feb 26, 2003 | 12:49 AM
CoopDog's Avatar
I have the DG motorsports big block hood, I didn't have to modify that anymore than I did for the original G-trim. Outside looks the same obviously.
