Want to upgrade to an 8-rib
Old Oct 30, 2005 | 01:25 AM
WHPLASH's Avatar
Default Want to upgrade to an 8-rib
What all do I need to upgrade to an 8-rib? Suggestions and cost.
Thanks
Old Oct 30, 2005 | 06:22 AM
EPP's Avatar
EPP
The ATI upgrade kit is $350.00 for everything to upgrade from the 6 rib to the 8 rib assembly. You will the then also need a new harmonic balancer to work with the upgrade, which is produced by ATI Performance Products, which is a different company. This harmonic balancer goes for $475.00, and you can get it in a 10% underdrive version, which is what we normally do. The 10% underdrive version will require two new longer accesssory drive belts, and we keep the Napa belt numbers for these two belts at the shop for quick reference. Bob
Old Oct 30, 2005 | 06:30 AM
Chas1's Avatar
SDCE has one for $675.00 complete. Be prepared to have your car down for a solid month. You have to ship them your tensioner bracket for them to modify. But it sure sounds a lot better with the new tensioner, no more bearing rattle.
Old Oct 30, 2005 | 09:58 PM
WHPLASH's Avatar
Does SDCE give you any puley(s) with that?
Do you have a link? Thanks
Old Oct 30, 2005 | 10:27 PM
onefastss223's Avatar
www.sd-concepts.com you get your choice of pulley sizes...
Old Oct 30, 2005 | 10:29 PM
its expensive but most everyone loves it and you really dont have any other choices...im ordering mine tomorrow by the way...
Old Oct 30, 2005 | 11:00 PM
WHPLASH's Avatar
That really don't sound like "everything to upgrade from the 6 rib to the 8 rib assembly".
Old Oct 30, 2005 | 11:01 PM
WHPLASH's Avatar
Thanks bro. Good luck with it!!!
Old Oct 31, 2005 | 05:15 AM
EPP's Avatar
EPP
Question
Why not? Bob
Old Oct 31, 2005 | 06:17 AM
WHPLASH's Avatar
Why not? Bob
BUT............you need the ATI harmonic balancer for $475 and misc belts.
But, I will more than likely go this route Bob.
Old Oct 31, 2005 | 04:01 PM
EPP's Avatar
EPP
Smile
Gotcha, now I see what you were talking about. I guess what I meant is the kit from ATI ProCharger is complete for $350.00, although to make it work you need the harmonic balancer. Sorry. Bob
