ASP pulleys with superchargers
Chris
But b4 I had gone with the 8 rib I did research to see if I could keep the ASP. I was told that I could keep it but I would have to go with a smaller blower pulley to see the same amount of boost. I was also told that I would have a greater chance of belt slippage because the belt will have less surface area to grab onto the pulley.
My advice, If you go with a blower just upgrade your belt system to an 8 rib and be done with any future belt slippage problems. You dont want the headaches. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Not worth the headache. Sell or don't buy the ASP. Also, you want a superior damper for a SC, not something worse than stock chewing up your bearings with the rotating assembly not dampened properly.
