Design on FMIC... HELP!
Old Oct 30, 2005 | 04:29 PM
Blownramair's Avatar
Default Design on FMIC... HELP!
Hey ya'll... i just put a griffin FMIC I/C on my 00 ws6. I feel the design could be a bit better? for the inlets and outlets should their be a angled inlet/ outlet? Mine is just a regular rectangle. What would be the best, most efficient, design for a FMIC on my car? How do ya'll have your FMIC setup/ design? Any and all help is appreciated.
Jayson
Old Oct 31, 2005 | 05:22 AM
EPP's Avatar
EPP
Check out the front mount intercooler made by Synergy Motorsports, which are a sponsor on here. I also have a lot of pic's of front mounts in the project car section of my website. Bob
Old Oct 31, 2005 | 10:31 AM
NA$TY-TA's Avatar
Jayson
You should be just fine... what are the intake temps now????? before the IC and after???? is it not working as well as youd like is that why your asking???
Kyle
Old Oct 31, 2005 | 04:47 PM
The air intake temps are only 6-8 degrees above ambient, according to w2w. I just feel my design could be better thats all. I looked at both websites, and synergy's too. I guess everyone else is running the same design that im running. I just spent a lot of money to have this FMIC installed and i only picked up 3-4tenths at 9lbs of boost. What belt drive on a D1 or F1 should i run to crank the boost up to, say, 15-18psi? would a 8rib with a spring loaded valve tensioner work? Thanks for your help guys
Jayson
Old Oct 31, 2005 | 05:15 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
I have a Griffin FMIC, and am very happy with it. Have put 17-21psi thru it.
Old Oct 31, 2005 | 05:49 PM
JETmn's Avatar
A design like that may cause some extra psi loss, but it will be pretty minimal. Personally I don't like that design, but I have seen a lot of really fast cars with the same design, so it can't be that bad. I just wonder what they would run with a better end tank design? With as big of turbo's as they run, a couple extra psi loss probably doesn't matter to them.
Old Oct 31, 2005 | 05:53 PM
LS1Tech Co-Founder
Why don't you post your total combo and your goals.
