Twin Turbo C5 Questions, Please Help !!!
Old Mar 19, 2003 | 03:03 PM
yellowc5's Avatar
Default Twin Turbo C5 Questions, Please Help !!!
I am 99.9% sure I want this kit, before I lay out some big denero's I am hoping the turbo guru's out there can answer a few questions I have.
1. Is Turbo Tech a solid company that provides a good product and supports it after the sale with both tech support and warranty.
2. I plan on keeping the engine and trans ( A4 ) stock. at 6lbs of boost can the stock engine and trans handle the power.
3. Will the stock converter work properly or should I install a higher stall. I want to keep the car tight.
4. I was advised to install new 42lbs injectors is this a good idea and can the stock fuel pump keep up with demand.
5. Is it a good idea to install a trans cooler with this setup.
6. Will the car have better driveability during normal driving with a twin turbo than it would with a head / cam / headers / intake package and similiar power when mashing the pedal to the floor.
Thanks for your help
Old Mar 19, 2003 | 07:55 PM
hondakiller's Avatar
Default Re: Twin Turbo C5 Questions, Please Help !!!
1. cant help ya here. i dont know anything about turbo tech.
2. ive heard the c5 transaxle is pretty stout but i could be wrong??? the driveline should be ok if you dont drag race it and you dont do any 150mph blasts down the highway. but to be on the safe side a hi-po trans rebuild wouldnt be a bad idea. engine should be fine as long as the tune is good and the engine was in good condition before. harlan made almost 600rwhp on the stock shortblock.
3. the stock converter might be a bad idea from a durability and performance stand point. might wanna do a small aftermarket one maybe a vig 2800 or something like that.
4. definently need new injectors 42lb'ers will work well. fuel pump MIGHT keep up if the engine stays totally stock besides the tt kit. a walbro 255 at least would be a good idea on the safe side though.
5. if you do a converter swap yes youll need a trans cooler.
6. definently yes. a heads and cam car of similar power would idle much worse and have worse driveability than even a mild turbo car and in most cases wouldnt even be able to make the same power as a turbo car.
im no expert so dont take this as gospel but this is my advice to the best of my knowledge but be sure to wait for others to chime in.
<small>[ March 19, 2003, 07:56 PM: Message edited by: hondakiller ]</small>
Old Mar 20, 2003 | 08:19 AM
yellowc5's Avatar
Please guys, some more feedback would be appreciated.
Old Mar 20, 2003 | 10:10 AM
CHRISPY's Avatar
You will definitely need a fuel system upgrade. (injectors and fuel pump minimum) as well as a LS1 edit tune on a dyno (Mustang dyno is preferred for Turbo tuning.
I think a Vig 2800 stall converter would work great in your situation.
Tranny cooler is a good idea and I would look at a built tranny option down the road as well.
Good luck,
Chris
Old Mar 20, 2003 | 03:09 PM
mkoch1's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif"> Will the car have better driveability during normal driving with a twin turbo than it would with a head / cam / headers / intake package and similiar power when mashing the pedal to the floor.
</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Nice thing about turbos is they don't effect your idle, mild acceleration, or cruising. You can drive around with getting into the boost and it won't effect the engine or fuel mileage. Step on the gas and your gone.
Old Mar 20, 2003 | 03:38 PM
zturbo's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif"> 1. Is Turbo Tech a solid company that provides a good product and supports it after the sale with both tech support and warranty.
</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Don't know now about their support but they were horrible when I had my system, Charged me for their welds cracking. George can be plain rude at times as well.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif"> 2. I plan on keeping the engine and trans ( A4 ) stock. at 6lbs of boost can the stock engine and trans handle the power.
</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Not sure to be honest if it will hold up or not. I would say yes at that level though.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif"> 3. Will the stock converter work properly or should I install a higher stall. I want to keep the car tight. </font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I would get a custom converter for your car, as it will loosen up with the extra power.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif"> 4. I was advised to install new 42lbs injectors is this a good idea and can the stock fuel pump keep up with demand.
</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">How much power are you wanting? I would at least put an inline as well in the situation
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif"> 5. Is it a good idea to install a trans cooler with this setup.
</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Yes. If you put more power into the motor a trany cooler will only help things out.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif"> 6. Will the car have better driveability during normal driving with a twin turbo than it would with a head / cam / headers / intake package and similiar power when mashing the pedal to the floor.
</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">For the power given I would do heads, cam and headers before a turbo system. They are proven and the driveablity is there and proven. MTI, ARE, etc.. have all got great setups. Plus MTI is always great to deal with, and stand behind their products if it was their fault.
Steven
Old Mar 21, 2003 | 05:24 AM
y2khawk's Avatar
</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">As I've not delt with them, i can't really comment. But i have heard mixed responses, then again all places seem to get that from time to time.
</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">The engine will handle it just fine. A proper tune is key for any power level with boost. At 6 psi on a stock motor you're probably in the neighborhood of 440 RWHP and 460 RWTQ with an auto. The trans should hold that, but a shiftkit might not be a bad idea.
</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Stall speed will incease. Normally increases with the square root of torque increase. It will probably stall in the high 2k RPM range with that boost level. Nice thing about a stock converter is it couples very efficiently up top and has the normal 4th gear lockup. You could get by with it, but a converter with a higher torque multiplier would be nice <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">You WILL need bigger injectors. No doubt about that. 42's will leave you room to grow, and cost you only a little more than say 36's. Plus, at 8psi the 36's will be on the edge. Not much to play with there. At 6 psi, the stock pump will live. Go much more than that, and it's time to add a new pump.
</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Yep
</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">A stock motored turbo car will have the same off boost drivability. A heads/cam car will have trade off's. All depends on the cam. But to be in the mid 400 RWHP range the cam will be noticible. But then again, you can't argue with 400+ RWTQ from 2800 on w/ a turbo setup <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> Not many HC setups can claim that <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old Mar 21, 2003 | 09:04 AM
smokinHawk's Avatar
There customer support, Well i dealt with them a little.
They overcharged me $50 for the 3" down pipe. Called them once, they were nice and said they'd send the money, next month, nothin, called them again, they said they'd send the money, a few months later nothing, called them again they said theyd send the money, still nothing.
<small>[ March 21, 2003, 09:07 AM: Message edited by: smokinHawk ]</small>
