LS1 Motorsport kit questions
Old Mar 21, 2003 | 01:09 PM
bo0oost's Avatar
Default LS1 Motorsport kit questions
Where does the LS1M single turbo kit tap in for oil feed and return?
Does the alternator have to be moved?
<small>[ March 21, 2003, 01:10 PM: Message edited by: bo0oost ]</small>
Old Mar 21, 2003 | 02:56 PM
RICE ETR's Avatar
Turbo Addict
Default Re: LS1 Motorsport kit questions
The oil feed is a fitting/Al plate that is attached right above the oil filter. Your stock one is held on with two bolts... and is not tapped... the one with the kit repaces it with the same hardware and has a small hole in it for oil and is tapped for the steel oil line/fitting which runs to the turbo.
the return used to be in the same hole as the oil drain plug... i do not know if this is the cause of any issues or not but i think it is now being required by Rob to tap the oil pan and put a fitting in to eliminate any oil drain/smoking issues.
Old Mar 21, 2003 | 02:57 PM
RICE ETR's Avatar
Turbo Addict
ohh.. and yes the Alt is moved to almost the exact same spot as the TT kit does... but only with a VERY nice poweredcoated bracket that holds the Alt and the stock tensioner..... good stuff..
Old Mar 21, 2003 | 10:56 PM
MIGHTYMOUSE's Avatar
wow i guess thats one good thing that came out of a prolonged install.. you managed to be awake during part of it!
i got pics of the kit on my site in sig, email me if you got any thing specific you may need a pic of.
Old Mar 22, 2003 | 11:58 AM
supersp0rt's Avatar
mighty...are you getting a new turbo log or just sticking with what you have?
