Paging Rob Raymer...
Old Mar 23, 2003 | 10:03 PM
TchargedLS1TA's Avatar
Default Paging Rob Raymer...
I was wondering if I could scab a part off your kit... I have the Turbo Tech kit and I wanna replace the x-over pipe with the one in your kit? Any chance I can get one? How much? Thanks..
Old Mar 24, 2003 | 06:44 AM
smokinHawk's Avatar
Default Re: Paging Rob Raymer...
Im not sure his will bolt up with the turbotech kit. I had mine redone at a local exhaust shop over the tranny, i have a M6. You loose ground clearance though. Ive scrapped a couple of times.
<img src="http://www.cofba.org/users/smokinhawk/TurboBeast-pics/xover2.jpg" alt=" - " />
<img src="http://www.cofba.org/users/smokinhawk/TurboBeast-pics/xover.jpg" alt=" - " />
Old Mar 25, 2003 | 04:55 AM
I dont see why it wouldnt bolt in.. The only problem I see the location of the wastegate on his kit compared to the TTi kit... What size is your X-over tube, 2-1/4"? How much did that run ya? Ground clearance isnt a real big concern with me, I dont drive my TA on the street much anymore...
Old Mar 25, 2003 | 05:42 AM
smokinHawk's Avatar
The waste gate is one of the main reasons it wont bolt in. also the driver sided header is alittle diffent (Rob says) from the TT one, cause of this it might not line up. He told me his 3" Down pipe wouldnt work. Good thing Turbotech just released their 3" DP.
The shop did the crossover for around $100.
I think your best bet would be to go to a custom exhaust shop and have them bend/weld you up a custom crossover.
I used 2.5" exhaust tubing.
Old Mar 26, 2003 | 01:33 AM
Why didnt you route yours under the tranny tailhousing? That probably would have given you more ground clearance.. I cant understand why the guys at TTi even dreamed of running the x-over tube infront of the engine.. I would rather sacrifice ground clearance than replacing steering boots and power steering lines often..
Old Mar 26, 2003 | 05:34 AM
smokinHawk's Avatar
NOt sure, i realy wanted it to go to a straight line, as short as tubing as posible.
But they ended up bending it that way. think it was because of the wastegate they werent able to route it like that
Old Mar 26, 2003 | 06:06 AM
SS00Blue's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by TchargedLS1TA:
<strong> Why didnt you route yours under the tranny tailhousing? That probably would have given you more ground clearance.. I cant understand why the guys at TTi even dreamed of running the x-over tube infront of the engine.. I would rather sacrifice ground clearance than replacing steering boots and power steering lines often.. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">The pipe on my LS1M kit, goes down from the right manifold, straight across, and then up to the left manifold. It doesn't go anywhere near the front of the engine.
Neither does Smokin's. His just takes a trip slightly forward (for extra clearance I assume) but it doesn't go forward of the cross member.
SC-
<small>[ March 26, 2003, 06:08 AM: Message edited by: SS00Blue ]</small>
Old Mar 26, 2003 | 10:39 PM
I know that, but thats how the Turbo Tech kit was designed..
