Blower Cam, for 6.0L 372c.i. motor.....
I need opinions on a cam that would be good for a 6.0L block honed .40 over to 372 c.i.
What duration should I go with, lift, will do 114lsa...
Any ideas, want to be able to make the most power out of this setup...
Re: Blower Cam, for 6.0L 372c.i. motor.....
What duration range should I stay in, lift, where would be the best point to shift it...the cam will for sure be on a 114lsa...
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by bybycops:
<strong> 250/250 605/605 113 </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">a single pattern on a blower motor??
sure would sound nice tho
Yea, defiently needs a split for F.I., those specs seem a little big though for a 372, but I still don't know what size to go with...
I'd probably run something in the 225 duration range on a 114 if you shift around 6800... maybe 224/230//114.
I don't like the idea of the iron block because of the increase in weight but the increase in bore size would be great.
Yea, John, didn't you know what my evil plan was, I starved myself, saved all the $ that I didn't eat, and put it towards the iron, I really didn't plan to do iron, but I guess its there for extra security....I'm down to 200 now, compared to what I was at 266 when I ran that 11.6
The parts all got ordered today, sent tom a Downpayment..
Jim is going to see if he can come up with some good specs for a cam for this motor, but I'm still open to opinions on here...
Thanks,
Bos
I wonder how a
224/230 .580/.590 114lsa
224/228 .570/.580 114lsa
These 2 could work
Thanks,
Bos
I wonder how a
These 2 could work
Yea, I heard about that too John, I do wonder how a single pattern would work though...
I just want a cam thats going to get the most power out of this F.I. motor...
Dug, I will respectfully disagree with you on that, I found that both Comp Cams and Cam Motion suggested traditional split cam grinds for supercharged applications, what is the basis of your stance? I talked to Terry at Cam Motions and Chris at Comp Cams (The guy who designed the XE-R family of cams)...
My only point to the Bosfather is not to go really big in duration because at some point the combo will peak at too high an rpms... A rule of thumb might be to look at NA grinds and add 500 rpms to calculate the peak HP.
I see, yea I think I'm defiently going to keep it in the range I posted..
I'm going to get a hold of Jim over at speed in the next few days to get some more opinions..
Well Bos it looks like ill be doing the bottom of the Auminum block. Over next winter.
I see you made ur choice on blocks. I
can see why you went with the iron block,
no more worries right. Well cant
wait to see the numbers. How much boost
you thinking on running? I wondering
how much I can do on the Aluminum?
Well good luck,and it was nice to
meet ya finally at the Speed Inc. dyno.
