turbo kits
Old Apr 5, 2003 | 05:09 PM
KTW's Avatar
KTW
Default turbo kits
I wanna do some research on ls1 turbo kits, can people please list some urls of the different manufacturers. I scrapped my origonal procharger idead and now its between a stroked h/c engine with bolt ons or a turboed motor.
Old Apr 6, 2003 | 03:58 PM
Noyzee's Avatar
8 second mod
Default Re: turbo kits
WWW.ls1speed.com New Iteams!
Old Apr 7, 2003 | 12:30 AM
smokinHawk's Avatar
http://www.ls1speed.com/ CAS turbo kit twin
www.turbotechnologyinc.com turbotech kit single
www.ls1motorsport.com ls1m kit single
Old Apr 7, 2003 | 02:12 PM
YSi-LT4's Avatar
Here is another company with one coming out.. I have seen the product(on my car <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> ) and the quality is top notch..
www.turbolocity.com
Old Apr 9, 2003 | 03:03 PM
1FastLs1ForMe's Avatar
How much power can a stock engine put down with a turbo and live?
Old Apr 9, 2003 | 11:29 PM
Robzilla's Avatar
i would probably say less than 500hp...if you keep it tuned right and don't run a whole lot of boost, it should last
Old Apr 10, 2003 | 09:42 PM
KTW's Avatar
KTW
Has anyone used the ls1 motorsports kit or the CAS twin kit? If so, what kind or results did you have? Do you have a built motor or stock internals. This turbo idea is getting to be pretty pricey.
Old Apr 11, 2003 | 05:05 PM
MIGHTYMOUSE's Avatar
i have the ls1m kit on a built motor.. yes it is expensive, but you pay to play.
my setup is for street.. but others have the same kit under construction with plans for big big output <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> should be very interesting in the next few months as we all hit the track.
Old Apr 12, 2003 | 11:02 AM
DaveSchott's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Hicks 2KTA:
<strong> i would probably say less than 500hp...if you keep it tuned right and don't run a whole lot of boost, it should last </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Not to be critical, but this is way off. with proper tune which includes fuel (upgrade tank pump, add 42lb injectors) and timing changes a stock internal engine can deliver 550rwhp for a very long time. Above that, it is recommended that rods/pins and pistons be swappped out. I believe Matt Harlan acheived just under 600 on a stock block, well maybe the valve springs were swapped. He put something like 20-30k miles on it before he took it apart, and the only real signs of wear were some weak points on the head gaskets, but nothing had failed. This is what I remember.
