supercharging and turbocharging
Old Apr 5, 2003 | 06:16 PM
LS1 Brent's Avatar
Default supercharging and turbocharging
is it possible to have both a supercharger and turbo chargers??
Old Apr 5, 2003 | 06:34 PM
abot316's Avatar
Default Re: supercharging and turbocharging
yes and no, it depends
yes if you had an *** load of $$$$$$
yes if the engine is strong enough to take all the psi
yes if you have the room
But on a late model f-body it would't be the best idea. it is best to apply the KISS theory( Keep It Simple Stupid)
the combination of both has been generally found in small displacement ie under 3 litres, all out race vehicles, and/or trailer queen/show vehicles.
on small motors the supercharger is there to provide instant boost and there for torque. then a massivly oversized can be brought in to build power on the top. this was common on old works rally cars.
Old Apr 6, 2003 | 01:07 PM
flynbludream's Avatar
I agree with these guys. Could you do it? Yeah but like they said, it would cost a crapload of money,would be probably damn near impossible to keep tuned and would probably run like ***.
Old Apr 7, 2003 | 12:32 AM
smokinHawk's Avatar
why?
realy net need unless for some exotic application
pretty much useless
Old Apr 7, 2003 | 11:29 PM
(A)SS WHIPER's Avatar
I HAVE SEEN SOME <img border="0" alt="[barf]" title="" src="graemlins/gr_barf.gif" /> IMPORTS WITH A ROOTS BLOWER AND A TURBO. IT WAS ON A <img border="0" alt="[barf]" title="" src="graemlins/gr_barf.gif" /> TOYOTA MR2. TURBO MAGIZINE HAD AN ARTICLE ON IT WITH IN THE LAST COUPLE OF MONTHS. THE SYSTEM WAS BAD. THE ROOTS BLOWER SUPPORTED THE LOW RPM POWER. ONCE THE RPMS WERE PAST THE AREA OF LAG FOR THE BIG TURBO, THE TURBO DID ALL THE WORK. THE WHOLE IDEA IS TO BE ABLE TO RUN A BIG TURBO AND NOT HAVE SERIOUS LAG ON THE LOW END. RALLY CARS HAVE USED THIS COMBO SINCE THE 80'S
Old Apr 12, 2003 | 08:57 PM
Racehead's Avatar
detroit diesels have used this combo for years. A turbo blowing through a roots style blower with a built in bypass. works great. Very heavy though.
Old Apr 12, 2003 | 09:52 PM
SScam68's Avatar
pulse wave supercharger.....run a search on google.
Its a hybrid of both and its going to make its debut pretty soon.
Old Apr 13, 2003 | 03:31 PM
Boosted LS1's Avatar
The problem with the chargers is they are not as mechanically or thermally efficient as a turbo. So if you use both on a turbo car, the turbo will be dragging the blower along through the upper rpm's. The blower is sapping power from the crank all the time. It would probably be worth considering quad turbo's if you want to shed mega-bucks but I can't see a huge advantage with a turbo and blower. Maybe it's got to be one or the other depending on the owner's requirements. Me, I'm with the turbo's but I have no experience with huge Rootes blowers and Hemi engines or anything else really big and american for that matter.
Old Apr 14, 2003 | 01:39 AM
GoldRamAir's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Mike at Boost Performance.co.uk:
<strong> The problem with the chargers is they are not as mechanically or thermally efficient as a turbo. So if you use both on a turbo car, the turbo will be dragging the blower along through the upper rpm's. The blower is sapping power from the crank all the time. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Not true, modern roots blowers have an air bypass valve when they are not needed and they require less than 1 hp to run when off boost.
Old Apr 15, 2003 | 03:44 PM
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by GoldRamAir:
<strong> </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Mike at Boost Performance.co.uk:
<strong> The problem with the chargers is they are not as mechanically or thermally efficient as a turbo. So if you use both on a turbo car, the turbo will be dragging the blower along through the upper rpm's. The blower is sapping power from the crank all the time. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Not true, modern roots blowers have an air bypass valve when they are not needed and they require less than 1 hp to run when off boost. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Maybe so, but it's still drag.
