ice water intercooler
Old Apr 18, 2003 | 09:54 AM
whitt1's Avatar
Default ice water intercooler
I have a intercooled Maqnacharger in my 01 Tahoe.The Magnacharger uses a liquid to air heat exchanger.I'm thinking about adding a flush valve into the lower water hose to my water resevoir so I can drain the heated water and fill the system with ice water between runs at the track.Is there a down side to doing this?Do you guys think I will see a increase in performance?
Old Apr 18, 2003 | 09:59 AM
Black LS1 T/A's Avatar
Moderator
Default Re: ice water intercooler
If you cool that intake air charge, you will see less detonation, which means you can increase boost safely (of course, that's more power <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> ).
You may even see better performance just by cooling the intake air.
Old Apr 18, 2003 | 10:56 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Definitely, I have been told that we can get a 1% increase in HP for every reduction of 10 degrees in inlet air temps.
I am doing a custom 3 core air to water intercooler for Project Blowzilla.
Old Apr 20, 2003 | 10:09 AM
whitt1's Avatar
Installed flush valve system drains in about 1 min should be able to change heated water to chilled water in less than 5 min.Next trip to the track I'll take a full ice chest and water cooler to see how it works.Maybe this will be a big help in the 90+ degree heat we see on summer nights in Memphis.
Old Apr 20, 2003 | 10:17 AM
GMC SKI's Avatar
Whitt1 you should try evans cooling stuff out
Might keep the temps down over regular coolant
evans cooling page
Check it out
jim
Old Apr 20, 2003 | 10:41 AM
whitt1's Avatar
My temps are't high I'm trying to reduce the forced air entering the engine to below ambient.Water dissapates heat better than antifreeze.I'm adding chilled water to retard the heating process.
